Shower Pan Detail Or Layers Of A Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 10-19-2017, 01:03 PM   #1
Rewards Points: 92
Shower Pan Detail or Layers of a Shower Pan
What is the correct beginning of installing a mortar type shower pan.
#1. Membrane then mud mortar bed for tile
or
#2. Pre-sloped mud bed, membrane then mud mortar bed for tile
PappyO is offline   Reply With Quote
Old 10-19-2017, 04:24 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Shower Pan Detail or Layers of a Shower Pan
PappyO,
The correct method for a traditional shower pan/tile job is #2....of course.
But, depending on where you are and who you hire, they might just cut some corners and hack it in and go with #1.
There are better methods that completely waterproof the shower. The one I used most is made by Schluter, look for Kerdi. www.schluter.com
Look around, then come back with any Q's.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-19-2017, 05:30 PM   #3
Rewards Points: 92
Originally Posted by JazMan View Post
PappyO,
Jaz
Thanks I've seen it (Google) both ways..........I really don't have the coin for Schluter, Kerdi as I have looked into it.
Old 10-19-2017, 06:51 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
How much more do you think it is?
You could do the base as in #1 and also use the Kerdi Drain, then just Kerdi the floor, curb and up the walls a foot or so Then switch to a cheaper waterproofing for the rest of the walls or skip it altogether.
It's a lot cheaper if you do it right the first time. The floor and the first foot or so, is the critical part.
Jaz
Mike Milam likes this.
Old 10-20-2017, 02:44 PM   #5
Rewards Points: 92
Jaz
I've talk to a few installers of the Schluter®-KERDI system and they all say wonderful things about the system but it's out of my budget for the shower. I do plan on using the Schluter®-KERDI drain and membrane system with Durock wall board.
Old 10-20-2017, 03:35 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
You say you don't wanna spend the $$$, then you say you're gonna use the drain and membrane just as I mentioned you could.
So good, the drain and membrane for the floor and up the wall a bit isn't going to cost very much. Probably less than $200. What is the alternative you were gonna use? The Kerdi way isn't very much more, but it'll work.
Jaz
Jaz
Old 10-22-2017, 07:09 AM   #7
Rewards Points: 92
Jaz
Jaz
My walk-in shower is 4' X 6'5". A Schluter Kerdi 48" x 72" Shower Kit With Stainless Steel Drain is $750.00
https://www.amazon.com/Schluter-Kerd...ower+kit&psc=1
I haven't done a materials take off for the Otay type PVC liner and mortar shower bed but a quick Google materials cost is?
5' X 6' Liner kit = $40
Drain = $30
Mud shower bed = $70
Misc materials = $50
Labor = free
Total = $190
Old 10-22-2017, 07:34 AM   #8
Rewards Points: 898
Drain = $30
Labor = free
Total = $190
Don't buy the kerdi kit. Get a few bags of deck mud ($15) make your sloped pan (1 layer) using the kerdi drain kit ($100) and kerdi membrane. Buy the bigger roll ($160) of membrane and you can use it over drywall on the walls too.
Staple some roof felt or house wrap on the subfloor. Then (with big galvanized staples) staple your lath ($12) on top of felt.
$287. Give or take.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
PappyO (10-22-2017)
Old 10-22-2017, 07:45 AM   #9
Rewards Points: 92
$287. Give or take.
Yes that is the plan and the suggestion from the tile distributor who sells the Schluter Kerdi System
Old 10-22-2017, 07:48 AM   #10
Rewards Points: 92
Do you recommend drywall over using a cement type wall board?
Old 10-22-2017, 07:53 AM   #11
Rewards Points: 898
Do you recommend drywall over a cement type wall board?
If you're going to membrane the whole thing, why bother with cement backer? Kerdi waterproofs it and Schluter recommends kerdi over drywall. Dont mud the drywall. If you need to fill in any tapers because the drywall is already done, use thinset.
Old 10-22-2017, 07:55 AM   #12
Rewards Points: 92
Use thinset with mess tape for the drywall joints?
Old 10-22-2017, 07:59 AM   #13
Rewards Points: 898
I don't think they even need to be taped. I was just talking about the tapers, if there are any. The kerdi membrane should act as a crack isolation between the drywall joints and tile surface. Jaz is the real tile pro so he might chime in and correct me here.
Old 10-22-2017, 08:07 AM   #14
Rewards Points: 898
Drain = $30
Labor = free
Total = $190
Remember here that if you go with the old school method that you still have to waterproof the cbu walls. That could be redguard for another $100 or so, plus a lot of time for multiple coats. Or the cheapest way is to do 2 layers of 6 mil plastic or roof felt behind the cbu, about $20. And of course that roll of grey mesh tape for $5.
Old 10-22-2017, 08:12 AM   #15
Rewards Points: 92
I was going to use Schluter Kerdi membrane over the cement board to water proof it
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
