Shower Pan And Cement Board - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 01:47 PM   #1
Shower pan and cement board
I am installing the Kohler Kathryn shower receptor and will have a tile surround. After reading the instructions my husband and I disagree with the wonderboard install. I believe it should rest on the flange lip and he says it should be 5/8" above the shower floor. He installed shims on top of the flange so the wonderboard it will lay beyond the flange. Who is right? Below is a link and the example is on page 8.
http://www.us.kohler.com/onlinecatal.../1009404_2.pdf
Thank you
Lori62 is offline   Reply With Quote
Old 08-15-2011, 03:33 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The wallboard should be (uniformly) within 1/8" of the top of the receptor rim. Then caulk that juncture.
Once the tile is installed...same thing...then caulk that juncture.
By the way...You are hijacking someone else's thread. If you continue this conversation please start your own thread.
XXX
Old 08-15-2011, 04:57 PM   #3
Thanks for the info. sorry, this was my first time posting and I didn't know.
The Following User Says Thank You to Lori62 For This Useful Post:
Bud Cline (08-15-2011)
Old 08-15-2011, 07:50 PM   #4
Retired Moderator
Rewards Points: 7,174
Lori--I started a thread for you.
