Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By BIG Johnson
  • 1 Post By Jack E
Old 10-09-2017, 07:29 AM   #1
Rewards Points: 193
Shower pan
I'm getting ready to build the mortar shower pan for our bathroom remodel. A couple of questions: - I plan on using 2x6s for blocking between the studs, will that bring the shower pan water barrier up high enough on the walls? - How do you handle the inside corners of the rubber shower barrier; will folding the corners create a protrusion that causes the backer board to not lay flat against the studs where it is on top of the fold? Thanks
Jack E is offline   Reply With Quote
Old 10-09-2017, 04:07 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Shower pan
I use 2x12's, but that's just me. You do want your PVC liner to rise up the wall a good bit. Since you won't be driving screws in the lower part of the PVC liner, having the 2x12's will give a good screwing point along the wall. As far as folding the PVC, yes, you will have some protrusion, but you can minimize it by folding it so half is on one wall and the other half is on the adjacent wall.
For information, don't forget to run at least 2x8's horizontally centered at about 34" AFF for attachment of grab bars, either now, or in the future.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Jack E (10-09-2017)
Old 10-09-2017, 04:09 PM   #3
Rewards Points: 898
Re: Shower pan
Don't forget blocking for a seat.
chandler48 likes this.
BIG Johnson is offline   Reply With Quote
Old 10-09-2017, 09:00 PM   #4
Rewards Points: 193
Re: Shower pan
Thanks for the insights and additional blocking recommendations. I bought a 5x7' piece of liner for a 3x5 shower so I'll go with 2x10 blocking.
Old 10-14-2017, 07:51 PM   #5
Rewards Points: 193
Re: Shower pan
A follow-up to my original post - I'm wondering about the need for metal lathe on the shower pan. I've read two "how-tos": lathe on top of the PVC barrier and lathe below the first mud slope layer. Both articles indicated the lathe was for mud support. Is this needed? The mud is laying on a horizontal surface, not sure how it would shift. Makes sense to tack lathe to the curb for tile. Also, one how-to source indicated just nailing the PVC to the studs - no need for blocking. Thoughts? Thanks
Old 10-15-2017, 06:11 AM   #6
Naildriver
chandler48's Avatar
Re: Shower pan
Install the lath on the floor and allow it to go over your berm. Then apply your pre slope. Follow that with your PVC liner and slope. No need for a second layer of lath. Remember, CBU comes in 3x5 sheets. If your dimensions exceed that you will need a good solid place to nail above the bottom off a stud without infiltrating the liner. Placing blocking there helps. You may even have to install additional studs at the 5' mark if your shower is longer.
Larry......
Old 10-15-2017, 07:31 PM   #7
Rewards Points: 193
Re: Shower pan
Thanks for the information. I'm still wondering what purpose the lath on the floor serves. I can see using lath on vertical surfaces - the shower curb - to give the mud/tile something to grab on to but on a horizontal surface gravity is going to keep the mud on the floor. I want to do it right but if I don't need the extra expense/labor of laying lath....
Old 10-15-2017, 07:40 PM   #8
Naildriver
chandler48's Avatar
Re: Shower pan
It helps keep the sand mix pack together and tying it to the berm for the long term. If you are worried about the $8, then there may be more to it than just doing it right. You have viewed the vids showing it being done.
Larry......
Old 10-16-2017, 07:13 AM   #9
Rewards Points: 193
Re: Shower pan
OK, I'll get some lath down, definitely want everything tied together properly.
Tiling pre-existing cement shower floor pan? KerryOn Kitchen & Bath Remodeling 3 07-14-2015 05:38 AM
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 02:45 PM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
