Shower Floor Installation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 09:40 PM   #1
shower floor installation
We are redoing our bathroom in the basement. We have used ceramic tile on the walls and are done with that part. Now the shower floor... We want to use ceramic tile on the floor also-to match the walls. We will be laying this tile on the concrete floor.
What do we use for adhesive? I have read about lacticrete-is this something we need to do-waterproof? This shower will not be used often, but we still want it done "right".
Any advice would be greatly appreciated!!
angie6365 is offline   Reply With Quote
Old 03-28-2012, 10:38 PM   #2
Rewards Points: 1,754
You might not like the answer....
You should have most definitely done the shower pan before tiling the walls...
ktkelly is offline   Reply With Quote
Old 03-28-2012, 11:25 PM   #3
How To Guides
How To Tips designed to help you complete a task from start to finish.
Hi Angie,
As noted above this section is for a quick reference section on how to to particular task. I've requested that this thread be moved to the appropriate section - Remodeling.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
angie6365 (03-31-2012)
Old 03-28-2012, 11:26 PM   #4
Shower pan...we were wanting to use the existing. We have a drain there-and the concrete "slopes" towards the drain. We purchased
?flexible? (not sure what to call them-they are 2"X2" and the size is 12 X 12 and they conform to an area not flat) tiles to go around the shower drain. These match as well as possible. Then the walk in part would have tile matching the wall. The shower is like a rectangle shape, with the shower head only accessable to the 3"X3' square. The entire enclosure is 3'X7', but the shower head will not be "flowing" on the entire 7' section. I hope this isn't too confusing.
Old 03-29-2012, 05:45 AM   #5
Retired Moderator
Rewards Points: 7,174
You need Hrdroban by Latacrete----this should have gone on before you tiled the walls--
Hydroban is a paint on waterproofing membrane---paint on the wall and floor at least 18" up the walls tape the seams between the walls and floor with tilers mesh--pay extra attention to the wall /floor seam and make sure that area is well covered. It works best with a special drain from Schluter or Latacrete --
A standard drain could work--pay extra attention to that point,also.
Set tiles with modified thinset--http://www.diychatroom.com/f80/mud-what-77763/
Old 03-29-2012, 12:05 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Is there a shower pan, or is it just a floor drain?
A few things should be understood.
1) tile is not waterproof.
2) grout is not waterproof. Sealing grout does not make it waterproof.
3) thinset is not waterproof.
A properly built shower should have 100% of the water heading down the drain before the first tile is set in place.
http://www.ontariotile.com/preslope.html
Don't count on tile, grout, or caulking as waterproofing.
Mike's link:
The Following User Says Thank You to Blondesense For This Useful Post:
Old 03-29-2012, 07:16 PM   #7
Retired Moderator
Thanks Blondsense---I will have the computer fixed in a day or two----Lots of helpful PMs with remedies.
Old 03-31-2012, 05:55 PM   #8
This is a floor drain only. I bought mapei aqua defense today, but we have not done anything yet to the floor.
I am confused on using this or any other product for a waterproof membrane. We redone our kitchen floor and used durock underneath. Thinset for adhesion. We didn't use any waterproof membrane of any kind. What is the difference?
I don't have a problem putting anything on the concrete slab to waterproof it. I just am confused as we didn't do anything like this in the kitchen. Maybe we should have? We have pets and water gets spilled ocassionally. We haven't had any problems thus far, and it has been down for 3 years.
The "helper" at Menards said to use a waterproof membrane for flexibility in shower floor. Is my floor going to move? If it does, what keeps the grout in between tiles?
Old 03-31-2012, 07:43 PM   #9
Retired Moderator
There is a lot more water hitting the concrete in a shower than the occasional water in a kitchen.
Tile and grout are not water proof--water will get to the concrete floor and soak it causing mold and eventually work its way into other areas.
That is why the shower pan and walls--especially the wall/pan seams need to be waterproof.
If not the water will get to the wall framing and cause rot and mold.
A properly made shower could be used before the tile is installed---because it is waterproofed.
Old 03-31-2012, 08:24 PM   #10
THANK YOU so much for your help!! We have taken down wall tile (20" up) (WHAT A JOB removing those was!) and just finished our waterproof membrane. We are waiting for it to dry.
We do understand the diff in kitchen/shower floors and needing a membrane on one not the other. I greatly appreciate your explanation!!
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
