Shower Enclosure - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2018, 05:35 PM   #1
Rewards Points: 111
Shower Enclosure
Hi all. My guest bathroom has a shower enclosure and tub that is made of some sort of plastic. I'm unsure how to tell if it's acrylic or fiberglass. I want to paint it. What type of "kit" would you all recommend? Thanks.
Jay2013 is offline   Reply With Quote
Old 06-14-2018, 06:36 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,640
Re: Shower Enclosure
I am not sure that is such a DIY friendly task. It is usually done by professionals who control the atmosphere to prevent fumes from entering the rest of the house and to maintain a smooth finish.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-14-2018, 10:20 PM   #3
Home Repairer
Rewards Points: 468
Yes, professional reglazing is on a whole other level compared to DIY resurfacing kits. First off is prep is key. ALL and I mean ALL soap scum and other contaminants need to be removed or you will not achieve adhesion. The pros will then acid etch the surface, prime and then spray on a finish coat. Unfortunately, the DIY home kits have less than stellar reviews. I have seen several where the paint literally peels off do to insufficient prep.
Reglazing by a pro would run somewhere around $400 depending on your bath configuration.
czizzi is offline   Reply With Quote
Cracks in Shower Enclosure. :( dgarstang Plumbing 2 08-28-2015 03:01 PM
Electrical behind shower enclosure Dansteel17 Electrical 2 03-17-2015 08:58 PM
Leaky Shower Glass Enclosure FLHomeOwner General DIY Discussions 10 01-05-2015 07:11 PM
What to put above shower enclosure JakAHearts Kitchen & Bath Remodeling 5 08-23-2010 10:17 PM
Bathroom Shower Enclosure charliefixit Building & Construction 1 04-08-2008 02:34 AM
