Shower Door.......issue! - Kitchen & Bath Remodeling - Page 5 - DIY Chatroom Home Improvement Forum
Like Tree12Likes
Old 12-01-2019, 08:06 PM   #61
Rewards Points: 1,280
Re: Shower door.......issue!
I will have to make a guide using a drill press actually......
french_guy is offline   Reply With Quote
Old 12-02-2019, 07:30 AM   #62
Rewards Points: 2,896
Does it really need to be perfectly straight and square?
huesmann is online now   Reply With Quote
Old 12-03-2019, 06:07 PM   #63
No, probably doesn't, and won't be really perfect anyway....
By the way, I asked 1 more time the "contractor" who did the job when he could come to take a look
He answered "Not anytime soon"
I said "Of course.............what does that mean"?
And he responded "Never"............!
This guy who IS a contractor, has no pride in what he does......!!!
He doesn't have the balls to at least come and show me I'm wrong when I say it wasn't installed properly. Maybe he already knows there is not much he can say anyway, so he prefers to ignore me....
Nealtw likes this.
The Following User Says Thank You to french_guy For This Useful Post:
123pugsy (12-04-2019)
Old 12-04-2019, 08:05 AM   #64
If he's on Yelp, etc. feel free to leave a bad review!
Old 12-04-2019, 05:57 PM   #65
Oh yes I will.....Yelp, Google, Facebook, my subdivision !!!!
I was thinking small claim as well, but it's going to be time consuming I guess, and I assume I can't fix it until the case is judged/closed
Old 12-30-2019, 05:25 PM   #66
I finally have some time to look at that......
So I've removed a small portion of the drywall to expose the stud
Well, of course, there is a knot where I was planning to drill and slide a dowel
I will have to drill more on the left I guess, and use 5" screws (the screw on the picture is 4")
Will a 1" dowel be large enough? I saw 1-1/4 dowel at HD, but it seems huge !!!
Shower door.......issue!-20191230_181604.jpg   Shower door.......issue!-20191230_181731.jpg
Old 12-31-2019, 07:59 AM   #67
Should be OK if it's hardwood, and as long as you get the penetration centered.
Old 12-31-2019, 11:15 AM   #68
Well, I guess the proverb "you get what you pay for" got verified 1 more time....I purchased a cheap 1" auger bit at Menards and made a test on a piece of stud: didn't cut much, lot of heat and some smoke. And I was drilling slow, but had to push hard to see "some cutting"...!!!
Will need to buy a quality one I guess
At least, I've found some #10 x 5" construction screws that should work fine:
https://www.menards.com/main/hardwar...339-c-8940.htm
Old 12-31-2019, 11:30 AM   #69
surferdude2's Avatar
Rewards Points: 1,576
I'd either use a brand new spade bit or a quality Forstner$$. An auger bit is likely to do more damage than good since they sometimes feed faster than they cut.
SD2
surferdude2 is offline   Reply With Quote
Old 12-31-2019, 11:57 AM   #70
Using spade or forstner bits, how do I make sure both holes are aligned?
Should I pre-drill frist both studs with a long standard bit, to make sure I can find the center on the 2nd stud with the spade bit?
Old 12-31-2019, 12:18 PM   #71
I've never needed to pilot drill either of those bits. It might even do harm since the bits need the meat at center point to hold them on path.
I see your point though, perhaps a small hole just for centering would be good... no bigger than 1/8". Maybe use a piece of welding rod or stiff wire to mark the second stud through the small hole in the first one, if you don't have a long enough small bit.
SD2
Old 12-31-2019, 12:22 PM   #72
My concern is since there is a gap between the 2 studs, how do I make sure to be on the same axis when I drill the 2nd stud?
Once passed the 1st stud, the spade or forstner bit will not be guided anymore, and might drill the 2nd stud off center....
Old 12-31-2019, 12:29 PM   #73
Yes, I understand the concern... I edited my previous post to address that concern.
SD2
Old 12-31-2019, 12:32 PM   #74
Yes, I was thinking 1/8" max
I don't have a long one though, but can buy one.....
surferdude2 likes this.
Old 12-31-2019, 12:47 PM   #75
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,598
I don't think you can.
Get a long 1/4" bit.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
