Shower Door.......issue! - Kitchen & Bath Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree12Likes
Old 11-26-2019, 03:05 PM   #31
Commercial. Const. ret.
surferdude2's Avatar
Rewards Points: 740
Re: Shower door.......issue!
Here's what I thought... drill at same height as existing holes, then insert dowels , pre-drill the dowels before screwing to prevent splitting. Bob's your uncle!
surferdude2 is online now   Reply With Quote
Old 11-26-2019, 03:08 PM   #32
Rewards Points: 1,280
My sketch is probably not accurate though
The wall between quarter bath and shower is probably a standard size wall, meaning 3-1/2" studs
french_guy is offline   Reply With Quote
Old 11-26-2019, 03:09 PM   #33
yep, it's exactly how I understood it.....seems a very good idea, with minimum repair afterward
Old 11-26-2019, 03:50 PM   #34
Now, the question is where to find HARDWOOD dowel rods?
Home Depot carries 1-1/4" dowel rod, but people are saying it's just pine.....might not be strong enough !!
Old 11-26-2019, 07:37 PM   #35
Rewards Points: 26
If you take your time and widen the holes, that missed studs, towards the other holes you can install these anchors that are rated @ 330 lbs in block. This will require no drywall patching. With the walls being lathed in, if done properly the lathe was fastened @ stud locations and to the stud. This will make the entire tile system on that wall a whole. These anchors are MORE than enough and you can probably find a 1/4-20 bolt with the proper head on it to match your hinge.
https://www.homedepot.com/p/Hillman-...6363/203754353
derrickm is offline   Reply With Quote
Old 11-26-2019, 07:42 PM   #36
Rewards Points: 6,486
I agree with Derrick - I'd use a good anchor. Moen makes a strong anchor called SecureMount, intended for their grab bars. The hole might be too big though. It's hidden behind the big circle of a grab bar cover, but check to see if the shower door frame would cover it.
jeffnc is offline   Reply With Quote
Old 11-27-2019, 06:40 AM   #37
I'm a little bit concerned about the toggle anchors
I cannot just drill a larger hole over the existing one, otherwise I fear the hinge will not cover them entirely
So it's more going to be "grinding" the 2 holes toward the center of the hinge
How should I do that? I don't want to end up completely messing the tiles !!!
Plus, and correct me if I'm wrong, there is like a flange on this type of anchor that rest on the finished surface....so the hinge will not sit flat, right?
Old 11-27-2019, 08:20 AM   #38
Rewards Points: 786
The studs you are screwing into are made of ............ pine
huesmann likes this.
Porsche986S is offline   Reply With Quote
Old 11-27-2019, 09:31 AM   #39
Rewards Points: 2,116
However, they have a lot more meat than dowels.
I would not pre-drill the dowels—no way to make sure you're gonna have the hole trued up or lined up after pounding in. Drilling the hole afterward should be NBD.
However, the more I think about it, the more I like just getting 7" screws and screwing into the stud adjacent to the door frame.
huesmann is offline   Reply With Quote
Old 11-27-2019, 09:36 AM   #40
That's right......but thicker so more grab?
Old 11-27-2019, 10:48 AM   #41
Well, yes....that would be the easiest solution
I purchased #10 and #12 wood screws yesterday to compare with the original one
#10 shank is smaller but the #12 head doesn't fit well in the hinge's chamfer
So it seems I would need to find #10 wood screws in 6.5" minimum....
Still fighting with the contractor actually....He doesn't want to come take a look, and says all screws were tighten, into studs or anchors. Being wood screws, it cannot be toggle style anchors then (that could have fallen into the wall)
So it must have been plastic anchors, and I should see them.......but I do not see anything !!!!
Old 11-27-2019, 12:40 PM   #42
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,524
Good riddance to a contractor that believes green drywall is a good thing behind the tiles.
.....And one that also lies to you. What you wrote about the anchors is dead on. There were none.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 11-27-2019, 12:50 PM   #43
Well, it's green drywall with metal lath+scratch coat (and it was not the same contractor - I do trust the one who remodeled the shower. He also did our kitchen)
It's just about the clown who install the shower door......
The Following User Says Thank You to french_guy For This Useful Post:
123pugsy (11-27-2019)
Old 11-27-2019, 01:49 PM   #44
For the dowel solution, I will have to make some tests with a spade bit, to see how tight or loose a 1" or 1-1/4" dowel fits into a hole made with a 1" or 1-1/4" spade bit
Cannot be too loose, and cannot be too tight !!!
Old 11-27-2019, 03:17 PM   #45
retired framer
Rewards Points: 5,866
I like the dowel idea but maybe a nylon dowel that will just take the screws that come with the hinge, An auger bit would be better than a spade bit.
Do not use flat bottom gables with scissor trusses.
