Shower Ceiling...... - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Nealtw
Old 01-17-2019, 05:38 PM   #1
Rewards Points: 1,368
Shower ceiling......
Hello
3 years ago, we had a contractor to remodel our bathroom (converting bathtub into shower)
We are happy with the results, no problem (tile on scratch coat)
After maybe six months, we noticed a gap between the top of the wall tiles and the ceiling (we left the ceiling as it was: drywall - we didn't really want to have it tiled)
The contractor came back and "fixed" with some caulk....not very nice though
Anyway, it's getting worse now: the gap is wider (maybe 1/4" inch) and it's ugly....We remodeled the kitchen last year, so maybe all the extra weight is also playing a role (mud bed, tile, heavy double oven that is somehow right underneath the shower upstairs) so I'm thinking that extra weight is probably accentuating that gap
What would be my option to make is nicer?
Shower ceiling......-20190117_175739.jpg   Shower ceiling......-20190117_175747.jpg   Shower ceiling......-20190117_175806.jpg
french_guy is offline   Reply With Quote
Old 01-17-2019, 05:44 PM   #2
retired framer
Rewards Points: 17,298
Re: Shower ceiling......
Originally Posted by french_guy View Post
Hello
Is this the tope floor with trusses for roof structure?
Nealtw is offline   Reply With Quote
Old 01-17-2019, 05:46 PM   #3
Yes, the shower is on the 2nd floor. The ceiling is drywall installed on joists 16" OC I believe...
Old 01-17-2019, 05:50 PM   #4
Property Mgt/Maint
Rewards Points: 8,210
1/4 inch is still caulkable in my book, but it all has to come out and start over.
If it is going to keep setting out maybe a small molding would be a better option
[political signature removed]
Yodaman is offline   Reply With Quote
Old 01-17-2019, 05:52 PM   #5
Guapo
Rewards Points: 11,950
At best, caulk is temporary fix. While quarter round is usually associated with wood molding, it is available in marble.
https://www.homedepot.com/b/Flooring...vZargcZ1z0p4qm
Guap0_ is offline   Reply With Quote
Old 01-17-2019, 05:57 PM   #6
retired framer
Can you stick your head up in the attic and see if they are trusses, 2x4s joined together with metal straps.
Old 01-17-2019, 05:59 PM   #7
Yeah.....I was thinking a vinyl cove molding (attached to the ceiling but not on the tile)
Or also install some PVC cladding on the ceiling then cove molding? But it seems difficult to find PVC planks !
Old 01-17-2019, 06:03 PM   #8
retired framer
Vinyl quarter round glued to ceiling only will allow movement.
https://www.homedepot.com/p/Royal-Bu...8001/203822132
Yodaman and chandler48 like this.
Old 01-17-2019, 06:52 PM   #9
Which adhesive would you recommend, assuming I don't want to use any nail?
Old 01-18-2019, 05:43 AM   #10
I will check tonight........Why is this important?
Old 01-18-2019, 06:49 AM   #11
Property Mgt/Maint
I would use a kitchen and bath adhesive caulk. Not sure you will find it in tan. Clear or white should be available.
Just one example:
Old 01-18-2019, 08:01 AM   #12
Naildriver
chandler48's Avatar
Rewards Points: 4,254
For secure adhesion, I would use an adhesive meant to do the job. A good one I have used is FuzeIt. High early tack off and extremely good adhesion.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-18-2019, 10:04 AM   #13
retired framer
They can lift in the center in the winter and go down again in the summer.
shower stall ceiling nickmick Kitchen & Bath Remodeling 8 08-29-2012 04:45 PM
custom tile shower ceiling maljeff Drywall & Plaster 1 08-21-2012 10:07 AM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
tiling a shower ceiling.... anedoll Remodeling 1 01-01-2007 07:04 AM
