Shower Base - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2018, 04:52 PM   #1
Rewards Points: 2
shower base
hi..
looking to buy dreamline French corner shower doors.
they are 34 1/2 x 34 1/2. the base is 36x36 and I need it right away. can I use any base for this shower that's 36x36? a delta base is in stock at home depot available for pickup tomorrow.
thanks...
angelamac17 is offline   Reply With Quote
Old 06-14-2018, 05:15 PM   #2
Guapo
Rewards Points: 11,950
Re: shower base
I think that the drain location has to be considered too. Someone else will confirm or deny that.
Guap0_ is offline   Reply With Quote
Old 06-14-2018, 10:28 PM   #3
Home Repairer
Rewards Points: 468
Re: shower base
The base will depend on what your intended shower wall treatment is going to be. If tiled,you will need a base with a tile flange on two sides of the corner unit. If the base has coordinating walls, then those must be used. So, really not enough information given what you have told us.
Installation instructions said you need to have at least 1 1/2" of flat space on the base curb to use this door.
czizzi is offline   Reply With Quote
Acrylic preformed 5 foot shower base padding? rivasdaniel90 Remodeling 7 10-19-2014 08:18 PM
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Stud wall return on a preformed shower base latelifebiker General DIY Discussions 5 11-30-2011 03:56 PM
Plastic shower base and concrete / leveling issue JoTeeBee Kitchen & Bath Remodeling 2 06-17-2011 07:46 PM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
