Should Imperfections In Travertine Be Filled Before Or After Sealing - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-17-2018, 09:13 PM   #1
Rewards Points: 110
should imperfections in travertine be filled before or after sealing
I am planning to use a similar color grout on my mosaic travertine mesh backed backspash
Some of the 2x2 tiles have holes and imperfections which I hope to fill with the grout
My question is if the tile is sealed with 511 impregnator sealer prior to adhering to the wall will the grout adhere to the holes?
provlima is offline   Reply With Quote
Old 08-17-2018, 09:27 PM   #2
ZZZZZ's Avatar
Rewards Points: 2,152
Re: should imperfections in travertine be filled before or after sealing
Generally, the grout will not stick as well to the sealed tile, especially if the sealer is allowed to puddle into the holes.
But grouting the unsealed tile may stain all of the tile surface. Depending on the batch of tile, the exact color of the tile and the type and color of the grout, it may or may not be a problem.
I would do a test run (hopefully you bought a few extra sheets). Seal and grout a few tiles, then just grout a few of the unsealed tiles and see what you like.
But either way, after grouting you probably should top seal everything (the grout and tile).
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
question about sealing travertine tile provlima Kitchen & Bath Remodeling 0 08-16-2018 05:54 PM
crack sealing stadry Concrete, Stone & Masonry 5 06-30-2018 08:45 AM
How to hide imperfections on ceiling stripedbass Drywall & Plaster 10 07-07-2015 09:02 AM
properly sealing stonework, travertine tstex Concrete, Stone & Masonry 16 01-08-2015 04:00 PM
properly sealing stonework, travertine tstex Concrete, Stone & Masonry 3 01-08-2015 03:05 PM
