Should I Use Tile Spacers In The Corners? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Studly
  • 1 Post By jeffnc
Old 04-20-2019, 11:40 AM   #1
Rewards Points: 443
Should I use tile spacers in the corners?
We're installing our first kitchen backsplash. A question for you experts: When tiling the inside corner of the walls, where the tiles meet from each wall, do you use a spacer between them? Or do you put a tile from one wall flush against the tile from the other wall?
Studly is offline   Reply With Quote
Old 04-20-2019, 02:52 PM   #2
Mike Milam's Avatar
Rewards Points: 96
Re: Should I use tile spacers in the corners?
I'm no expert, so wait for others to comment. When I do an inside corner, I 45 the ends that meet and leave a space equal to the spacers. When I grout I don't grout the corners. I caulk with a grout colored matching caulk. In my simple mind, the movement of houses tend to crack corners from time to time. Caulk won't tend to crack.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 04-20-2019, 03:41 PM   #3
Rewards Points: 443
Thanks for the advice. Yes, I was planning to caulk that corner joint.
Mike Milam likes this.
Old 04-20-2019, 05:44 PM   #4
Rewards Points: 1,604
If you're planning to caulk the corner, I'd put a spacer in just to keep the tiles separate. If your spacers are wide, you could just put it in sideways, i.e. separate the tiles the thickness of the spacer, not the width.
huesmann is offline   Reply With Quote
Old 04-25-2019, 02:34 AM   #5
Rewards Points: 6,266
You use a tile spacer. Cutting the edges at a 45 degree angle is unnecessary and overkill, since the final grout line is indistinguishable. It's not a bad idea to caulk this line if the house is not very old or if movement is expected.
Johnny_inFL likes this.
jeffnc is offline   Reply With Quote
How to use tile spacers Sdiver2489 Flooring 4 02-16-2019 06:35 AM
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
