DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Kitchen & Bath Remodeling (https://www.diychatroom.com/f80/)
-   -   Should I use tile spacers in the corners? (https://www.diychatroom.com/f80/should-i-use-tile-spacers-corners-657649/)
Studly 04-20-2019 10:40 AM
We're installing our first kitchen backsplash. A question for you experts: When tiling the inside corner of the walls, where the tiles meet from each wall, do you use a spacer between them? Or do you put a tile from one wall flush against the tile from the other wall?
Mike Milam 04-20-2019 01:52 PM
Re: Should I use tile spacers in the corners?
I'm no expert, so wait for others to comment. When I do an inside corner, I 45 the ends that meet and leave a space equal to the spacers. When I grout I don't grout the corners. I caulk with a grout colored matching caulk. In my simple mind, the movement of houses tend to crack corners from time to time. Caulk won't tend to crack.
Studly 04-20-2019 02:41 PM
Thanks for the advice. Yes, I was planning to caulk that corner joint.
huesmann 04-20-2019 04:44 PM
If you're planning to caulk the corner, I'd put a spacer in just to keep the tiles separate. If your spacers are wide, you could just put it in sideways, i.e. separate the tiles the thickness of the spacer, not the width.
jeffnc 04-25-2019 01:34 AM
You use a tile spacer. Cutting the edges at a 45 degree angle is unnecessary and overkill, since the final grout line is indistinguishable. It's not a bad idea to caulk this line if the house is not very old or if movement is expected.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
