Self-Leveling Concrete Underneath New Tub? Or Not Necessary? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-15-2016, 12:20 AM
Rewards Points: 14
Self-Leveling concrete underneath new tub? Or not necessary?
Hello.
Is it absolutely necessary to lay self-leveling concrete on the entire bathroom floor, including under where the new bathtub is going to be placed, or can I install the new bathtub first and just lay the self-leveling concrete everywhere else?
Yes, the new tub would then be slightly recessed below the level of the new concrete I lay down.
ChuckHammer is offline
Old 03-15-2016, 03:22 AM
JUSTA MEMBER
Rewards Points: 3,556
Re: Self-Leveling concrete underneath new tub? Or not necessary?
What is the tub made from?
Fiberglass, steel, other.
A fiberglass one needs all the support that you can build into it.
Those dumb Styrofoam blocks stuck on it for support will decay in a few years and there will be no support left, and with even a light (200 lb) person in it cracks will develop and it will be junk, and need replacement.
As I asked what material is it made of?
ED
de-nagorg is offline
Old 03-15-2016, 01:46 PM
Rewards Points: 14
Actually I haven't purchased the tub yet, but either enameled steel or cast iron. Cast iron tubs are pretty pricy though.
I should mention the bathroom floor is a solid concrete slab about a foot thick.
I've seen videos online of professionals self-leveling the floor without removing the tub. They just put weather stripping in front of the tub (and around everything else) and pour.
Is this okay to do with a steel tub on a concrete floor?
Old 03-15-2016, 05:01 PM
JUSTA MEMBER
As long as you make sure that no moisture can get underneath it ever, this plan is good.
This is on steel, or iron, any other with those Styrofoam supports will decay eventually , causing a catastrophe.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
ChuckHammer (03-15-2016)
Old 03-15-2016, 05:14 PM
Retired Moderator
Rewards Points: 7,174
I would set the tub first---then pour on the self leveling compound---
oh'mike is offline
Leveling a concrete floor in converted den? WNB Flooring 0 08-20-2013 11:31 AM
Options to floor leveling compound for concrete repair. akimbo Concrete, Stone & Masonry 0 07-26-2013 10:20 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 11:58 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Self leveling concrete questions Dave K Flooring 3 08-21-2011 05:49 AM
