Which Sealant To Use - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-23-2013, 03:23 PM   #1
Rewards Points: 111
Which sealant to use
I finished tiling and grouting my bathroom. It's a walk in shower, with an acrylic shower pan. It's time to seal. Does anyone recommend one sealant over the other? Which brand? Is it necessary to seal the tile as well? FIY: I have 12x12 glazed porcelain tiles and a flex type grout.
Jay2013 is offline   Reply With Quote
Old 09-23-2013, 05:25 PM   #2
Retired Moderator
Rewards Points: 7,174
What are you sealing? The grout?
Old 09-23-2013, 05:52 PM   #3
Rewards Points: 111
Yea, the grout on the walls and floor. Must the tile be sealed too?
Old 10-05-2013, 07:02 AM   #4
Rewards Points: 195
you can't seal a glazed tile (porcelain or ceramic) just the grout joints. But you said you have a "flex grout". Urethane and Fusion Pro don't need to be sealed. What brand and type of "flex grout" did you use?
A great caulk is Laticrete's silicone with micro ban. Cut a small opening in the tube and use Fantastic to lubricate your finger when smoothing.
olzo55 is offline   Reply With Quote
Help! Issue with marble tile backsplash sealant DrDIYer Tiling, ceramics, marble 7 06-10-2013 01:52 AM
Which Sealant for Tile Grout? greentrees Tiling, ceramics, marble 2 05-20-2012 10:23 PM
Countertop sealant leaves granite with a dull finish? HeyItsJoel Tiling, ceramics, marble 6 05-31-2010 06:00 AM
Can I use this sealant (3M FD150+) on Class B flue? KatieAK Building & Construction 1 04-12-2010 04:35 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
