Roofing Felt/Plastic With Durock Good Enough? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 03-26-2018, 05:25 PM   #1
Rewards Points: 640
Roofing felt/Plastic with durock good enough?
I went to pick up 4 sheets of kerdi boards today, as I'm looking at this thing, I felt like I'm over doing (over spending) it for a shower tub surrounds. It was about $100 per board
The previous installation was with roofing felt stapled to studs then durock sheets. I inspected and everything is dry and have no signs of water damage from behind the roofing felts. So after 15 years of heavy use and it still hold up, why not do it again?
For under $100 I can put new felts in and durock. Saving the Kerdi boards to use in the master bath steam shower where it's mandatory.
If I have to spend an extra 2 hrs to put up durock vs Kerdi boards and save $300 and have no negative affect, IMO it's worth it.
Would anyone recommend against this thought process?
dannieboiz is offline   Reply With Quote
Old 03-26-2018, 08:22 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,222
Re: Roofing felt/Plastic with durock good enough?
6 mil vapor barrier and Durock will work just fine. Be sure you use alkaline resistant mesh tape and thinset on the seams, corners and cubbies. I also like to use Redgard on the cubbies since it could hold water, as well as the seams (overkill)
dannieboiz likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-26-2018, 08:25 PM   #3
Rewards Points: 640
Since I will be using kerdi here and will probably not want to use the $100 Kerdi niche, redgarding the niche sounds like a great idea.
Thanks for saving me money!
btw: would this work? and do I have to use any special staples or something like the one below works?
https://www.lowes.com/pd/10-ft-x-25-...eting/50414220
https://www.lowes.com/pd/Arrow-Faste...taples/1068807
Old 03-30-2018, 04:17 PM   #4
Rewards Points: 640
I picked up a roll of this, before I put it on, just wanted to confirm that this is OK to be used before putting the hardiebacker on
https://www.homedepot.com/p/GMCraft-...4480/202527472
Roofing Question Recommendations RoofingTrades Roofing/Siding 28 05-02-2014 03:46 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 07:48 PM
Vent Flashing for Low Slope Mineral Surface Roll Roofing Thumbhammer Roofing/Siding 4 05-22-2011 05:52 AM
Good book on roofing? Dave K Roofing/Siding 2 04-22-2011 02:23 PM
New Roof Jeff DIY Roofing/Siding 7 04-08-2009 03:01 PM
