Roofing Felt Between Subfloor & Underlayment - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-01-2018, 05:56 PM   #1
Rewards Points: 36
roofing felt between subfloor & underlayment
I've stripped the flooring down to my subfloor. Is felt needed below the new underlayment given I insulated my entire crawl space?
DoIt1ceRight is offline   Reply With Quote
Old 03-01-2018, 07:07 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: roofing felt between subfloor & underlayment
What style of subfloor do you have there?
The only time I have seen or used tar paper between layers is where the bottom layer is 1 x 6 tongue and groove or shiplap or regular s4s lumber. Back in the olden days, before plywood. And way before OSB.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-02-2018, 12:47 PM   #3
Rewards Points: 36
I believe you would classify my house as of the "olden" days; the original structure was built in 1949. The subject subfloor is constructed with t&g 2x4s. Back then I guess the only form of available insulation was newspaper found in my exterior walls or some sort of tar paper laid between the subfloor and underlayment. There is now ample insulation, hence my original question. Thanks!
Old 03-02-2018, 05:16 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,612
No. It all has to breathe., and your underlayment is particle board. We read all the posts. Any moisture collected by the felt will cause the particle board to swell.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 03-02-2018, 08:55 PM   #5
Rewards Points: 36
"Half of Communications is Listening, and You can't Listen with your Mouth."
Yea, your quote is good. However your answer added important info but failed totally to explain a solution, hence, your answer is not helpful to the end result.
Old 03-03-2018, 05:47 AM   #6
Naildriver
chandler48's Avatar
Just what do you need to "totally explain" anything. Don't use a vapor barrier. The layers need to breathe. If you use the vapor barrier, moisture will collect between the layers and the particle board will absorb water and buckle. But I find that I repeat myself.
I asked my 9 year old grandson if he understood what I was talking about and he said he did.
My quote is working.
Since you have insulated below, the insulation will have a vapor barrier built in and it should be facing up towards the floor.
Larry......
Roofing Underlayment jpm6621 Roofing/Siding 33 06-24-2013 09:54 PM
Leak in roof due to satellite. Is this the way to repair it? amodoko Roofing/Siding 8 06-16-2013 02:37 PM
Tyvek, Generic House Wrap, Roofing Felt, or? Earnie Building & Construction 22 10-17-2012 10:58 AM
Leveling an old subfloor - sand vs roofing felt whitesjtaa Flooring 5 05-07-2012 05:57 PM
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
