Reusing 60 Year Old Terrazzo Shower Base. How To Keep Edges Watertight - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-28-2018, 09:52 AM   #1
Rewards Points: 6
Reusing 60 year old terrazzo shower base. How to keep edges watertight
I have my shower room down to the studs. It has an old terrazzo shower pan which I hope to reuse. It had an inch high metal (lead?) edging around it. It was fairly decayed so most of it has broken off or been removed.
I have Wonderboard lite and Redguard ready to go up, but I'm not sure if I need something to further waterproof the section between the shower pan and the backerboard? I had a drywall guy in and he mentions that there is usually a rubber strip on new shower pans that prevents water ingress.
Is there something I should do before putting on the wonderboard / tile?
Reusing 60 year old terrazzo shower base. How to keep edges watertight-1.jpg   Reusing 60 year old terrazzo shower base. How to keep edges watertight-2.jpg   Reusing 60 year old terrazzo shower base. How to keep edges watertight-img_20181228_101831757.jpg   Reusing 60 year old terrazzo shower base. How to keep edges watertight-img_20181228_101843283.jpg
Gribbler is offline   Reply With Quote
Old 12-28-2018, 04:42 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,132
Re: Reusing 60 year old terrazzo shower base. How to keep edges watertight
^^This is the story to focus on.
TarheelTerp is online now   Reply With Quote
Old 12-28-2018, 04:48 PM   #3
Guapo
Rewards Points: 11,950
How about a full pic of the entire base? What do you plan to use for the walls?
Guap0_ is offline   Reply With Quote
Old 12-28-2018, 05:05 PM   #4
kwikfishron's Avatar
Rewards Points: 284
It needs to be replaced (and I think you already know that).
You can hope and wish this and that all you want but with all of the work that you have into this so far don't skip this critical step.
kwikfishron is online now   Reply With Quote
Old 12-28-2018, 06:14 PM   #5
Rewards Points: 6
Seems like a sledgehammer is the order of the day, thanks!
Tags
shower base , shower base leak , tiling shower walls , water barrier
Acrylic preformed 5 foot shower base padding? rivasdaniel90 Remodeling 7 10-19-2014 08:18 PM
Sterling shower base dennis blocker Kitchen & Bath Remodeling 7 07-03-2014 05:56 AM
repair material for terrazzo shower base Ken Beck Kitchen & Bath Remodeling 0 01-31-2012 11:26 AM
Need to replace 34 x 48 shower base (has surround walls inside shower base lip) justplumducky Plumbing 3 09-10-2011 09:59 PM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
