Resurfacing A Bathtub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By oblvnnwtnjhn
  • 1 Post By Canarywood1
Old 12-10-2018, 09:16 PM   #1
Rewards Points: 119
Resurfacing a bathtub
I have a nice green bathtub
I don't want a nice green bathtub.
I know there are some products out there that can 'paint' a bathtub.
Other than the colour, it is perfectly fine.
Its a one piece unit with wall and ceiling, so replacing it will be an excessive amount of work and expense.
Im hoping to recoat it.
Its fiberglass.
Looking for suggestions on a product to use.
Obviously I want a long-lasting professional looking result. That said, how hard, or how much of a learning curve is there on such products - I prefer doing things on my own, but something of course are better left for the professionals....
Thanks in advance!
phantasm72 is offline   Reply With Quote
Old 12-11-2018, 05:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 598
Re: Resurfacing a bathtub
I have seen one done by a professional in a rental house. Looked great when he was done but I saw it a few years later and it had more than a few chips on the edges. Replace the tub.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 12-11-2018, 05:57 AM   #3
retired framer
Rewards Points: 18,434
You have to be absolutely sure it is fiberglass gel coat, acrylic is a different process.
Fiberglass cars are painted every day.
Old 12-11-2018, 06:22 AM   #4
retired painter
Rewards Points: 1,318
Using the right coating and proper prep are the keys to a successful tub paint job. Most diy tub repaints fail because of improper or lack of prep!
mark sr is offline   Reply With Quote
Old 12-11-2018, 07:26 AM   #5
Rewards Points: 17,884
I would not do it, but if I had to I'd be using something like this.
https://www.westmarine.com/buy/inter...11?recordNum=1
Old 12-12-2018, 07:29 PM   #6
Rewards Points: 160
Bathworks kit if used properly and with correct prep methods has the best results. If metal, I recommend powder coating, we had ours done for $450 here in Northern Alabama. He took it all the way down to the cast iron, which is good because some of the porcelain had cracked over the years, which will bubble if just coated over.
Nealtw likes this.
oblvnnwtnjhn is offline   Reply With Quote
Old 12-13-2018, 09:48 AM   #7
Rewards Points: 332
Was this tub powder coated in place? If so, how was it heated to melt the powder?
Tymbo is offline   Reply With Quote
Old 12-13-2018, 12:43 PM   #8
Rewards Points: 160
No, I took it to their shop. It has to be blasted down to bare surface, coated, then baked on in a giant oven. It will outlast you and probably your home.
Old 12-13-2018, 06:05 PM   #9
Rewards Points: 1,032
I know a friend that had his tub and surround done , was done with gelcoat and the guy that did it applied it with a high end HVLP unit , this was about 9 years ago and it looks as good today as the day it was applied , and the tub is used daily for showers.
Nealtw likes this.
Canarywood1 is online now   Reply With Quote
Old 12-14-2018, 08:44 PM   #10
Rewards Points: 119
Nice
Any idea of the cost of having something like that done? I prefer DIY, but if a professional job is going to last at least a decade and look new, that sounds good to me
Old 12-14-2018, 09:24 PM   #11
retired framer
Old 12-14-2018, 10:03 PM   #12
CodeMatters's Avatar
Rewards Points: 6,486
I did a tub 10 years ago with Klenks. Looked good when it was done but
don't know how it held up as I sold/moved 6 months later. If you use an
epoxy paint like Klenks ventilate REALLY well. That sort of thing doesn't
usually bother me but I think that stuff put scabs on my brain ---Lesson
learned. -(
CodeMatters is online now   Reply With Quote
Old 12-15-2018, 11:19 AM   #13
Originally Posted by phantasm72 View Post
Nice
He said it cost him $300.00 , but considering how long it's held up it was a bargain , although i'd guess he never expected it to last as long as it has.
Tiling overlap on the new installed bathtub any solution ? nyounaki Tiling, ceramics, marble 8 07-28-2018 09:56 AM
Bathtub with wainscot? kanonka Kitchen & Bath Remodeling 0 05-10-2017 09:49 AM
Needing new bathtub. Completely lost. Caiterz Kitchen & Bath Remodeling 4 03-08-2016 07:00 PM
Should I change my bathroom "Pinky" bathtub? ChicityChicity Kitchen & Bath Remodeling 3 08-03-2013 11:20 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
