Replace Vent Fan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-12-2015, 06:17 PM   #1
joe645's Avatar
Rewards Points: 16
Replace Vent Fan
My bath has a standard 7" circular vent fan (120v) on a dedicated single switch box. I want to replace it with a fan driven heater. Is there anything on the market that will do?
joe645 is offline   Reply With Quote
Old 01-14-2015, 05:47 PM   #2
Rewards Points: 169
Usually the heater units are wider than the standard "square" housing vent fans. You'll probably have to do a little drywall cutting. If you have access to the location from above - meaning if it's a second floor bathroom with attic access above - it will be a lot easier to retrofit the unit.
Make sure that the circuit can handle the wattage of the heater. Otherwise the wiring, should be pretty straight forward if you buy a "single-switch" heater unit. If you need two or more switches (e.g. heat/no heat option, light/heat combos, etc.), things could get a little tricky if you're not comfortable with adding wires.
Hope that helps.
mikeyp78 is offline   Reply With Quote
Can I split a main drain vent stack? -- SpinFly Plumbing 14 08-15-2012 10:32 AM
Ridge Vent Installed - what to do about soffits nickc3 Roofing/Siding 3 07-02-2012 04:26 AM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
Best way to vent garage and attic mikeinaz Roofing/Siding 8 03-22-2012 09:48 AM
Replace Power Vent? Cmeller Roofing/Siding 1 05-16-2011 04:20 PM
