Replace Bath Tub In Small Area - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2013, 12:37 PM   #1
Replace bath tub in small area
I removed my cast iron tub and it was a standard 60 x 30 x 14 tub. The new tub I'm ordering is the same dimensions but when the old tub was installed the builder notched the studs to fit it in. It was like they frame the area slightly too small. How do I fit the new one in without tearing up my complete bathroom?
johnsorious is offline   Reply With Quote
Old 06-12-2013, 02:02 PM   #2
Rewards Points: 17,890
If the old one fit and you got it out, why can the new one fit in the same spot?
Old 06-12-2013, 02:28 PM   #3
Retired Moderator
Rewards Points: 7,174
Joe--the member said the studs were notched around the tub--
Post a picture if you can---How deep are the notches? How is the room laid out?
Some reframing is likely---need more info---
Old 06-12-2013, 02:48 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,134
Have a picture?
Sister some 2X's onto the old framing.
Old 06-12-2013, 05:56 PM   #5
Rewards Points: 186
Going to have to slice the existing studs so you can drop the new tub in, then sister new 2x4's to build the wall back out.
Dan
djlandkpl is offline   Reply With Quote
Old 06-12-2013, 06:17 PM   #6
I couldn't get the tub out and if I could then I wouldn't be able to lift it out since it was cast iron. I ended up smashing it with a sledge hammer. I'll have photos up later
The Following User Says Thank You to johnsorious For This Useful Post:
oh'mike (06-12-2013)
Old 06-12-2013, 09:19 PM   #7
Anyway to remove the studs on the side where there is no drain and replace them with 2 X 3's?
Old 06-16-2013, 07:05 AM   #8
Bill Kearney
Rewards Points: 1,174
Do everyone a favor, consolidate your questions on this house to one thread. That way folks interested in helping you can follow the progress and not end up duplicating things already posted by others.
wkearney99 is offline   Reply With Quote
Old 06-16-2013, 09:12 AM   #9
Rewards Points: 996
i removed a tub like this. by myself. in one piece.
http://www.argostarz.com/wp-content/...odel-ideas.jpg
if i am not here, it means i cannot long in. but i can read.
Fix'n it is offline   Reply With Quote
Bath Tub: repair VS replace Chance65 Plumbing 1 07-19-2012 12:03 PM
Fix or replace copper main stack? jimmyfloyd Plumbing 1 06-28-2012 04:59 PM
How to find the Right Company For Marble BAth Reno? VA area zip 22152 Gisella Kitchen & Bath Remodeling 0 06-03-2012 08:15 AM
16 years old and small leak, time to replace? supermaxhd HVAC 16 05-19-2010 07:09 PM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
