Removing Tub And Replacing With Vanity. Can I Use The Same Plumbing? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-13-2018, 09:42 AM   #1
Rewards Points: 160
Removing tub and replacing with vanity. Can I use the same plumbing?
Hi everyone, my home was built in the 50's and has one very small bathroom. My plan is to remove my bathtub and replace it with a vanity of the same size to make the bathroom feel much larger. Attached is a link to some pictures.
Will I need to relocate pipes or can I just route a sink to the existing drain that is connected to the tub?
Any guidance or optionions is much appreciated!
All floors will be redone and proper painting and patching will be done as well, so please ignore those inevitables.
https://imgur.com/a/ZXPQD
mathbishop is offline   Reply With Quote
Old 03-13-2018, 10:01 AM   #2
JUSTA MEMBER
Rewards Points: 3,648
Re: Removing tub and replacing with vanity. Can I use the same plumbing?
Where is the new shower/ bath going to go then?
There should be few problems making the connections to the existing drain, and water supply.
ED
de-nagorg is online now   Reply With Quote
Old 03-13-2018, 11:03 AM   #3
Rewards Points: 160
ED
You can see the small shower to the right of the tub in the picture. Its a seperate enclosure. I will be addressing that separately.
-MB
Old 03-13-2018, 11:10 AM   #4
JUSTA MEMBER
-MB
Ah. I missed that, that will give you more room, if you rid the room of the vanity, and storage that is between the door and toilet.
Routing the new vanity plumbing might take a bit of extension, of the existing , but I think that it is fairly simple to do.
ED
Old 03-13-2018, 11:42 AM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
if these are the original pipes you are dealing with I believe you should
replace them & in doing so re-route them all where you need them...
are drain & or water pipes original?
all the original vanity piping will also need to be dealt with as well
as your shower faucet is most likely back to back to tub faucet...
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
