Removing Sakrete Sand Mix Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Windows on Wash
  • 1 Post By JazMan
  • 1 Post By Build4Sure
Old 02-06-2017, 09:45 AM   #1
Rewards Points: 4
This weekend I did my first shower pan attempt in a 3x5 shower. I used the Goof Proof Quick Pitch system to do this. However; after the Sand Mix dried one side had a valley that puddled water. From what I'm reading it is most likely best to just redo the shower pan and chalk it up to a learning experience. I don't mind doing this bud I really don't want to redo the liner membrane. Is there a relatively easy way to break up the sand mix and remove it without ruining the liner?
Build4Sure is offline   Reply With Quote
Old 02-06-2017, 09:57 AM   #2
JUSTA MEMBER
Rewards Points: 3,594
Re: Removing Sakrete Sand Mix Shower Pan
It takes weeks / months for concrete to fully cure, so your mix is still "green", and should break up easily with a hammer, just be gentle as one can be with a hammer.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Build4Sure (02-06-2017)
Old 02-06-2017, 09:57 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,298
Hammer is the best way to go and just check the liner. They are pretty durable.
de-nagorg likes this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 02-06-2017, 12:10 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
If it's only "off" in one spot and is otherwise in good shape, why not keep it a fill the valley? I'd have to see it, but this might work for you. Otherwise a hammer, and it's gone in a few minutes.
Goof Proof eh? Remember to over fill, then go back a scrape/screed away the excess to make it perfectly flat as you want it.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-06-2017, 12:39 PM   #5
Rewards Points: 4
Ok, thanks for the advice. I'll break it out with a hammer and this time I'm not using the goof proof system. I'm going to make a level line around the cement board and use the 2x4 method to tamp it level around the edges first then go from there. The goof proof system only comes with 6 sticks when I feel it should definitely have at least 8. Anyway, hammer it is
Old 02-06-2017, 01:04 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
What tools other than a few 2x4's and a level are you using?
Jaz
Tags
quick pitch , sakrete , shower pan
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
Removing Tub and Shower Doors Wyo Building & Construction 2 08-20-2012 09:04 PM
Removing shower tile when chicken wire was used as backer board STEELER929 Kitchen & Bath Remodeling 11 02-06-2011 03:05 PM
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 08:23 PM
Removing water stains for shower tile grout? acyate General DIY Discussions 2 08-07-2009 06:38 PM
