Removing And Replacing Kitchen Backsplash - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 1 Post By MTN REMODEL LLC
  • 2 Post By Mike Milam
  • 1 Post By huesmann
  • 1 Post By Mike Milam
  • 3 Post By Mike Milam
Old 03-27-2019, 04:07 PM   #1
Mike Milam's Avatar
Rewards Points: 126
Removing and replacing kitchen backsplash
I installed glass/ceramic mix backsplash a couple years ago in our kitchen. Now the bride wants to changed because of kitchen color change. I used mastic to install it. Any tips on getting the old off without having to replace the drywall?
Thanks in advance.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 03-27-2019, 04:51 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,568
Re: Removing and replacing kitchen backsplash
Mike....
I really don't know...just some thoughts....
Might be trial and error...
You might get lucky if that drywall was painted, especially with maybe a gloss.
Maybe a heat gun and a ridgid 4" blade worked very carefully tile by tile.
I'm gonna watch this thread ... if that issue ever occurs to me.
If you don't chew it up to bad, maybe a coat of Gardz will give you enough to go over it without replacing.
Best
Mike Milam likes this.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Mike Milam (03-27-2019)
Old 03-29-2019, 03:32 PM   #3
Rewards Points: 5,532
Once you get the first tile off, then it's easier to get tiles off by tapping a wide chisel between the tile and wall. The key is to get the chisel moving completely parallel with the tile and wall, never angled or prying against the wall. A multitool with scraper blade can also work well.
Then hopefully the tile will come off without much argument, especially since most tile jobs suck and aren't adhered well. (I've been on floor tile demo jobs where you can go around kicking off half the tile.) To be fair, wall tile never has the same forces applied to it that floor tile does, so it doesn't need to installed all that securely to work.
If/when there is some damage to the wall (pretty much unavoidable in some circumstances, such as starting the first tile or in awkard corners, then you can simply use Gardz if you wish for small problems, or fill in big chunks with drywall setting compound (smaller and less shrinkage and faster setting than standard drying compound.) However if the damage is small spots and the tile is big enough, frankly no one will ever know. If installing small mosaic, then that is a different story and you're going to want nice, flat wall to work with.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Mike Milam (03-29-2019)
Old 03-29-2019, 04:00 PM   #4
Mike Milam's Avatar
Rewards Points: 126
This what I plan to remove.
Old 03-29-2019, 04:11 PM   #5
retired framer
Rewards Points: 12,236
When I have done that I decided that the drywall will be gone but I tried to save a couple inches above and around the cupboards.
I have put a hole in the walls between studs and go inside with a knife and cut lines in the back of the drywall so it will break some distance away from the cupboards.
It is a crap job all around.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 03-30-2019, 02:15 PM   #6
Rewards Points: 1,087
Mike, that looks like the type of backsplash that's matted together. Once you get a couple of tiles loose you may be able to just pull each section off by its mat.
huesmann is offline   Reply With Quote
The Following User Says Thank You to huesmann For This Useful Post:
Mike Milam (03-30-2019)
Old 03-30-2019, 06:43 PM   #7
Mike Milam's Avatar
Rewards Points: 126
It does have the mat, but it's no match for that mastic. Just rips to pieces.
Gymschu and Nealtw like this.
Old 03-31-2019, 04:54 PM   #8
Ah, alas!
Old 04-14-2019, 12:10 AM   #9
Mike Milam's Avatar
Rewards Points: 126
Just a quick update. I spent about 4 hours and got about 2 running feet of tile off. BUT, I was doing so much damage to the drywall I gave up. I popped a single row of tile off around the perimeter and took an oscillating tool and cut around the whole area and then pulled drywall and tile off in 3 or 4 pieces. I put hardi backer back in place of it.
Nealtw likes this.
Old 04-17-2019, 08:15 PM   #10
Mike Milam's Avatar
Rewards Points: 126
Got the new backsplash up. Still have to grout and caulk.
Removing and replacing kitchen backsplash-cabnet-backsplash-1.jpg   Removing and replacing kitchen backsplash-cabnet-backsplash-2.jpg
Gymschu, huesmann and Nealtw like this.
replacing subflooring under door without removing wood floring qfwfq Building & Construction 14 01-06-2019 08:36 PM
Removing Old Formica Kitchen Backsplash??? etsherman Kitchen & Bath Remodeling 5 11-10-2018 11:54 AM
Removing Laminate Backsplash and Replacing Cabinets ayclobes Remodeling 1 05-17-2012 08:04 PM
Replacing kitchen sink hockeymom Plumbing 2 08-31-2009 11:42 AM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
