Removing And Replacing Bathroom Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 11:37 AM   #1
removing and replacing bathroom tile
I need to remove old tile there is window thinking about repacing 1940s tile with some thing new tile covers whole bathroom what would be the easiest way and most cost efficint route to take?
rainajz is offline   Reply With Quote
Old 02-11-2012, 11:49 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
First of all, are you talking about walls, shower, tub surround, or all of the above?
If you're going to replace old tile with new tile, plan on taking out the drywall with it, and replacing it with cement board (the best surface for tiling).
If you are doing a shower, or tub surround with shower, keep in mind tile and grout are not waterproof. You need something to stop the water from penetrating into the wall. There is more than one way to do this.
Pics are always a help here.
Replacing Tile Floor in Shower banglenot Flooring 9 05-23-2011 09:05 PM
Failing bathroom tile floor--best options quinten Flooring 3 11-16-2010 06:56 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 11:35 AM
Removing old 6" Tile and Replacing with 6" tile Mikey_B Tiling, ceramics, marble 1 07-09-2009 09:01 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
