Removing Plastic Anchor From Wood (installing Blum Hinge To Replace Old One) - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Woody416
  • 1 Post By SeniorSitizen
  • 1 Post By Nealtw
  • 2 Post By Tymbo
Old 07-12-2018, 02:12 PM   #1
Rewards Points: 30
removing plastic anchor from wood (installing Blum hinge to replace old one)
The corner cabinet door in the condo I'm dealing with had Grass 1203 170 degree hinges. They had some damage (the bottom one hadn't been installed correctly and broke so the top one had been taking all the weight and was wonky too.
I bought a couple of Blum 170 degree hinges. As seen below, the previous installation had some plastic anchors in the wood. The mounting plate for the hinge does not match up with these plastic anchor holes and they're also making the hinge plate not flush.
How the heck do I remove these? And after I remove them, do I use wood filler and will that hold a screw when dry? The new screw positions are close to these. (I hope I'm being clear -- trying to say part of the new screw hole might overlap a bit with the old ones.)
removing plastic anchor from wood (installing Blum hinge to replace old one)-img_20180712_144541867.jpg
Woody416 is offline   Reply With Quote
Old 07-12-2018, 02:43 PM   #2
Rewards Points: 1,406
Re: removing plastic anchor from wood (installing Blum hinge to replace old one)
Use a pair of needle nose pliers and just keep going around the outside of the anchor and pinching it inward, then pull.
Whittle a piece of wood (3/16" dowel maybe ?) to fit each anchor hole tight. Glue it in with TiteBond wood glue. Let cure over night. Insert new hinge and screws.
Gregsoldtruck79 is offline   Reply With Quote
Old 07-12-2018, 02:51 PM   #3
Rewards Points: 30
Thanks, I'll try the dowel approach. It's always fun when you watch videos/read articles that suggest 99% of the hinges will match up the holes perfectly and you'll be finished in a second. Then the reality is you'll need another trip to HD because you're in the 1% :-)
At least it's a nice day for errands.
Gregsoldtruck79 likes this.
Old 07-12-2018, 04:14 PM   #4
Rewards Points: 30
The needle nose pliers approach is easier said than done. In about an hour, I've manged to remove 1 of the 4 plugs. really hard to get a grip on the plug edges.
Old 07-12-2018, 04:22 PM   #5
Rewards Points: 1,466
Maybe a screw in it would give more to pull with.
Woody416 likes this.
Old 07-12-2018, 04:38 PM   #6
retired framer
Rewards Points: 18,814
Old 07-12-2018, 04:39 PM   #7
Rewards Points: 334
put the screw back in, but leave enough to grab with a claw hammer. Be warned, the dowel may chip out the melamine/ laminate when you pull it out.
I've done this dozens of times. Easy peasy
Nealtw and Woody416 like this.
Tymbo is offline   Reply With Quote
Old 07-12-2018, 08:14 PM   #8
Rewards Points: 30
Well, the screw and pliers trick worked on two of the remaining three plastic anchors but the third is well and truly stripped so a screw won't hold. And so a five minute chore continues into the night as the needle nose tugging isn't budging it.
Old 07-13-2018, 06:53 AM   #9
Rewards Points: 334
If you can find a wider screw, you might be able to get it to bite. Otherwise, try drilling the plastic dowel with a bit slightly smaller than the dowel diameter. If you go slowly, it won't spin and you can drill out most of the dowel.
Then clean up the rest with needle nose and sharp utility knife.
Old 07-13-2018, 07:10 AM   #10
A spiral Dremel bit will cut it out.
Tags
blum , hinges , kitchen cabinet , screw holes
Consealed hinge to replace 3/8 in inset hinge Susienew Remodeling 1 05-23-2018 07:38 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Installing a wood burning stove. rickjames8 Building & Construction 13 10-30-2012 10:02 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 09:35 PM
installing wood blocking sonnycrockett General DIY Discussions 8 06-15-2008 05:39 PM
