Removing Old Cement And Mesh From Studs - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-23-2016, 11:10 AM   #1
Rewards Points: 30
Removing old cement and mesh from studs
Hello,
We pulled down old cement mesh wall and the tile from the 50's yesterday.
Got most of it down however we still have some stuck to the studs and intermingling with the regular wall.
The slats that they seem to have glued to the studs to hold the concrete mesh is so stuck to the studs we can even get a pry bar behind it to pull it off the studs.
I posted a picture of what is left from the demo and how it is between regular wall and shower area.
any suggestions of how to get this stuff off would be most appreciated.
Picture attached.
jcjst21 is offline   Reply With Quote
Old 05-29-2016, 06:48 AM   #2
Rewards Points: 2,472
Re: Removing old cement and mesh from studs
Cheap chisel. It's still sharp enough to dig into the cement without damaging anything else. Don't chisel over an empty space. Grinder and diamond dry blade, but costly for just one time use.
You also can leave it there. Put a straight edge on the drywall and see if old cement bumps out. If below, clean up the edge, stud and continue with sheathing then join them with thinset. Redguard then tile.
carpdad is offline   Reply With Quote
Replacing Shower Tile... Can I Reuse Cement Backing Over Wire Mesh Behind Tile? MetalMan8008 Kitchen & Bath Remodeling 39 04-21-2016 04:03 PM
gravel tar roof repairing mazizbit Roofing/Siding 7 04-09-2012 09:52 AM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 11:48 AM
do i need to use a scratch coat and wire mesh on cement board(floor) Limit54 Flooring 10 12-03-2009 06:24 PM
Removing Wire Mesh And Scratch Coat/Mortar atw58 Flooring 2 07-25-2009 09:44 PM
