Removing An Island In A Condo. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-07-2017, 08:41 PM   #1
Rewards Points: 112
Removing an island in a condo.
Hi all,
I will be removing an kitchen island in a condo, and want to make sure I bring the right tools to the job. Anyone know how these are usually fastened to the floor?
There is a cabinet on one end, so i'll take out the drawers and have a look at whats underneath. My question is really with the other end.. its just a 1/2 piece of board that runs down to the floor and holds the whole side up (empty space for barstools underneath most of the island). The piece of board butts right up to the laminate and I cant see sign of fastening around it. It also appears to sit on top of the laminate.. any idea how this end is fastened? does the laminate have to come off?
xyzz is offline   Reply With Quote
Old 04-07-2017, 09:43 PM   #2
JUSTA MEMBER
Rewards Points: 3,566
Re: Removing an island in a condo.
Normally the top is the last thing attached.
Look underneath the outside top to maybe find some brackets with screws.
Lift off the entire top, and look in the inside bottom for cleats, or other fastenings that the island was built around.
ED
de-nagorg is offline   Reply With Quote
Old 04-08-2017, 04:55 AM   #3
jlhaslip's Avatar
Rewards Points: 708
Often there are blocks of wood attached to the floor by screws and the Island is then screwed to the blocks.
Remove the toe kick coverings to see the screw heads and go from there.
Pictures would help.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-08-2017, 03:54 PM   #4
Rewards Points: 112
added pictures here:
http://imgur.com/a/6o3kI
any ideas?
Old 04-08-2017, 04:01 PM   #5
JUSTA MEMBER
In the one picture the legs at the floor look loose, .it looks more like a table just sitting on the floor.
Get under it and look for attachment screws from the tabletop to the legs.
Remove those and it all should fall down.
ED
Old 04-08-2017, 04:12 PM   #6
Rewards Points: 112
ha. you're right. it does move. Ok, now to take the quartz top off. I guess it they are usually only glued/ caulked on?
Old 04-08-2017, 04:19 PM   #7
Rewards Points: 112
added a few more pics of countertop:
http://imgur.com/a/MXhbG
looks like the quartz countertop is on top of a 1/4 sheet of mdf. dont see any glue/caulking spots yet.
Old 04-08-2017, 04:19 PM   #8
JUSTA MEMBER
ED
See above in RED.
ED
Removing wall mount sink connector OldHomeJen Plumbing 6 11-27-2013 08:45 AM
looking for optimal solution to address noise issue in condo ilyaz Flooring 1 10-31-2012 12:11 PM
Removing tile; electric tile stripper or rotary hammer? mackaz Flooring 0 07-21-2011 06:22 PM
Cost/how to obtain liability insurance for DIY condo work? esk8mw Building & Construction 8 07-18-2011 06:49 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
