Removing Glued Down Jetted Tub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-08-2016, 07:30 PM   #1
Rewards Points: 2
Removing glued down jetted tub
I just started work on a bathroom remodel project and step 1 is to remove the existing jetted tub. I had no issue disconnecting pretty much everything that the tub is connected to except the floor itself. It seems that the builder used the expanding foam to insulate/glue the tub down to the concrete floor and no amount of human force is even budging it. I really wanted to donate the tub to habitat for humanity as there is nothing particularly wrong with it, but I am coming to the realization that this is probably not going to happen now.
The only thing that I can come up with is to cut the tub into pieces and get to the parts that are glued down and chisel the foam out. I am hoping that someone here might have another, better, idea that might allow to salvage the tub. If it is not possible to salvage, does anyone have an idea of a better, less brute force way, of removing the tub?
bigssa is offline   Reply With Quote
Old 05-08-2016, 07:34 PM   #2
Rewards Points: 17,890
Re: Removing glued down jetted tub
Most likely there not even going to want it.
Start cutting.
You did remove the drain, right?
Old 05-08-2016, 07:35 PM   #3
Rewards Points: 2
Start cutting.
Yes. I removed all plumbing lines and the drain of the tub.
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
Remove Screwed and Glued Subfloor anon8933 Flooring 1 03-15-2012 01:14 PM
removing access panel on jetted tub zamboni Plumbing 2 01-30-2012 09:23 PM
Removing glued hardiebacker board labaldi Flooring 1 08-02-2008 12:09 PM
removing glued wainscoating diysteph General DIY Discussions 4 07-16-2007 04:38 AM
