Removing Floor To Ceiling Pantry Cabinet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By ZZZZZ
  • 1 Post By ZZZZZ
  • 1 Post By rdy2go
  • 2 Post By rdy2go
Old 09-15-2018, 09:14 PM   #1
Rewards Points: 67
Removing floor to ceiling pantry cabinet
I am planing the removal of our kitchen cabinets and have a problem figuring out how to deal with two 36" wide cabinets. Assuming I remove back and side screws, I see no way to tilt the units forward to take them out. I wonder how were they installed. Is there a trick or do I have to resort to cut them into pieces to get them out ?
rdy2go is offline   Reply With Quote
Old 09-15-2018, 09:26 PM   #2
JUSTA MEMBER
Rewards Points: 3,600
Re: Removing floor to ceiling pantry cabinet
Pictures, can we get pictures?
No way to advise without more data.
ED
de-nagorg is online now   Reply With Quote
Old 09-15-2018, 09:34 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,166
If you can't just slide them out, more than likely at some point new flooring was added on top of the existing floor or subfloor, thus blocking the front of the cabinets.
Yes, you'll have to carefully cut it into pieces and remove it piece by piece.
de-nagorg likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 09-15-2018, 09:51 PM   #4
Rewards Points: 67
Originally Posted by ZZZZZ View Post
If you can't just slide them out, it would appear that at some point new flooring was added on top of the existing floor or subfloor, thus blocking the front of the cabinets.
Lets assume I could slide them out. They will still be bracketed tight between floor and ceiling, so I would still be unable to tilt forward to take them out horizontally. Do I make sense? Am I missing something.
Old 09-15-2018, 10:03 PM   #5
ZZZZZ's Avatar
I see what you are saying.
It might depend on how the cabinets are installed.
Do they go exactly tight to the ceiling? Is there crown molding or whatever at the top covering a gap?
Is there drywall on the ceiling above the cabinet?
Were the cabinets custom built in place on the job site?
Photos would help.
Old 09-15-2018, 10:18 PM   #6
Rewards Points: 67
Photos would help.
No crown molding. At most there might be a veneer like strip glued to the top cross member to compensate for ceiling irregularities. The top edge of the higher doors is very close to the ceiling. May be 3/4" to 1".
The cabinets are the original in the house, circa 1992. Could the two large units have been assembled/glued in place? Is that something cabinet makers would do?
The cabinets have no face frame.
I will take some pictures tomorrow.
Old 09-16-2018, 06:22 AM   #7
retired framer
Rewards Points: 18,736
At the end of this, they show how to install and that might give you some ideas.
Remove the full height side and the toe kick.
The Following User Says Thank You to Nealtw For This Useful Post:
rdy2go (09-25-2018)
Old 09-16-2018, 10:37 AM   #8
Rewards Points: 67
From the video I see that they probably installed the floor frame and lift/slide the cabinet over.
Here are some pictures
Removing floor to ceiling pantry cabinet-pic_1.jpg   Removing floor to ceiling pantry cabinet-pic_2.jpg   Removing floor to ceiling pantry cabinet-pic_3.jpg   Removing floor to ceiling pantry cabinet-pic_4.jpg   Removing floor to ceiling pantry cabinet-pic_5.jpg
Old 09-16-2018, 10:46 AM   #9
retired framer
So what is the plan, remove and re install or selvage or???
I would attack the kick no mater how it was built so it could be cleaned up and installed with a new kick.
Old 09-16-2018, 11:48 AM   #10
Rewards Points: 67
The plan is to send as much as we can to the habitat restore.
One idea was to temporarily move the pantry unit to the basement to give us some service while the remodeling goes on. Then to the restore. But at this point I am not sure they are going to come out in one piece.
We may move to basement another smaller unit.
Nealtw likes this.
Old 09-16-2018, 12:02 PM   #11
retired framer
I think you pull the one above the fridge, move the fridge and remove the panel and then you will see better what will come out, Just leave it screwed to the wall till you have cleared below.
Old 09-16-2018, 12:21 PM   #12
Naildriver
chandler48's Avatar
Rewards Points: 3,640
I agree with the kick being installed post construction of the cabinet. It may be that the kick base can be either slid out or destroyed in place (collapsed) so the cabinet can be removed intact. New kick can be built.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 09-16-2018, 03:01 PM   #13
Rewards Points: 67
The visible kick is part flat board, part baseboard. I wonder if there is something like a 2x4 box behind it. The refrigerator will be moved early tomorrow. Then I will tear down the drywall on the right of the cabinet and then see about removing the unit above the fridge.
I have another issue I need to solve, which is cutting the corian countertop in manageable pieces. Most of it is in a long peninsula, 30" deep, with access from two sides. I will reinstall some of it in the garage bench for plant potting and such.
I wonder what would be better, routing or sawing. I will try to clamp a guide and make multiple sawing passes.
Old 09-21-2018, 09:32 PM   #14
Rewards Points: 67
Today, I had a guy interested in getting the tall cabinets, give me a hand to get out the tall cabinets. I had made the prep work removing the dryewall wrapping and the couple of 2x4 supporting the drywall. The cabinets came out very easy, shifting out and then down off the base. We tilted the cabinets forward, barely missing the ceiling. Those things where heavy!
So they are out and gone.
Thank you guys for the tips.
de-nagorg and Nealtw like this.
Garage renovation/vaulted ceiling & removing "ceiling joists" brandonlaundry Building & Construction 7 02-20-2011 11:27 AM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Removing a kitchen cabinet, I give up... cold-fish Remodeling 4 07-19-2009 07:15 PM
Removing ceiling mounted cabinets medimaging5047 Remodeling 3 07-16-2009 03:30 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
