Removing Corner Shower Tile (with Pictures) - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 02:30 PM   #16
Jason,
You should check out the one-piece shower bases by KBRS at www.showerbase.com.
They offer one in the style you are interested in, although you would have to compare their dimensions to see if it aligns well with your drain.
I recently installed their 34x60 unit, and have been very happy. Easy to install with a solid flat bottom which you simply set in a thinset bed, and you can use normal thinset to apply tile to it. For further info, check out my previous posts on the Tile Redi Shower Pan Question thread.
Good luck.
jonbt is offline   Reply With Quote
Old 03-30-2012, 09:19 PM   #17
Rewards Points: 39
Originally Posted by oh'mike View Post
No need to remove the ceiling if it's okay---the only difficulty might be the neww drywall might not be the same thickness as the old--leaving a wide gap to fill at the new wall/ceiling joint.
Great point. So I will need to find drywall that would be the same thickness. I will spend some time and look into this.
Let's assume for now I don't want to affect the ceiling. I may change my mind, but let's assume this for now. Based on this would I then do the following:
1) Cut the drywall one foot OR half foot below the ceiling and then remove it.
2) Replace the drywall with new drywall.
3) Tape the seems of the drywall.
4) Mudd it up.
Would this sort of be the approach? Any pro tips or suggestions?
JasonCA is offline   Reply With Quote
How to make wall smooth after removing tile? cheapchick Remodeling 20 04-09-2012 01:59 PM
Tile Shower Remodel Questions roybfr Kitchen & Bath Remodeling 1 07-31-2010 02:43 PM
properly ensuring shower is mold-free before regrouting? mdude85 General DIY Discussions 14 07-23-2010 03:02 PM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 09:50 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
