Removing Cabinets Above A Refrigerator - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 02:12 PM   #1
Removing cabinets above a refrigerator
Hi! I just bought my first home (a condo) and the space for the fridge is very short. The upper cabinets have to be taken down. They appear to be put up with large staples directly into the drywall on the back and side. The other side is attached to the next set of cabinets. I am sure that although there is a separation between the cabinet sets, they all went up in one piece. We can't get them to budge! Any ideas on how to get them down with minimal dry wall damage?
HaleyCa is offline   Reply With Quote
Old 06-14-2010, 06:06 PM   #2
kwikfishron's Avatar
Rewards Points: 286
Are you sure there aren’t some screws holding them to the wall you can’t see?
I’ve never seen cabinets stapled to the wall.
kwikfishron is offline   Reply With Quote
Old 06-14-2010, 06:33 PM   #3
Registered User
Rewards Points: 526
If the staples are 1/4" or smaller, they are holding the cabinet together. There should be some screws in the hanging rail inside the cabinet at the top. OR, above the cabinet into the drywall, on the last inch of back panel. Check under the cabinet on the back panel for screws, too. They are also screwed to the others, near or under the hinges of the doors.
Be safe, Gary
Old 06-15-2010, 09:50 AM   #4
Rewards Points: 150
No way they are hanging with staples only. Should be screws there. Check above the cabinet, and below it. Also tied together, check face frame, sides, could be connected from the cabinet next to it too.
slickgt1 is offline   Reply With Quote
Old 06-16-2010, 03:57 PM   #5
Rewards Points: 5,348
The cabinets are screwed, both together and the wall. Look for screws in the faceframes or in the frameless cabinets in the front of the units. It's possible they are hidden under the hinge plates.
Ron
Removing textured finish from kitchen cabinets jbwaechter Remodeling 6 10-04-2010 01:12 PM
Removing ceiling mounted cabinets medimaging5047 Remodeling 3 07-16-2009 03:30 PM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 05:47 AM
removing wall tiles for new cabinets measure thrice Tiling, ceramics, marble 1 02-03-2009 07:03 AM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 08:02 PM
