Remove Very Old Countertop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 07:59 PM   #1
Remove very old countertop
Hi there! I need to remove a 50's wood/linoleum/chrome countertop. Im assuming it's nailed onto the cabinets...under the linoleum? where do I start...? I am keeping most of the cabinetry (if possible). I just want to replace the countertop. Any suggestions would be WONDERFUL!
Heykat is offline   Reply With Quote
Old 05-30-2012, 08:04 PM   #2
Rewards Points: 17,884
Can you hold the top closer to the screen so we can see what it is your trying to do?
Or just post a picture.
Look up inside the cabinets in the corner to see if there's screws hold it in place.
Old 05-30-2012, 08:11 PM   #3
Framing Contractor
Rewards Points: 50
Free up an outside corner using a drywall knife and a flat bar. Carefully work your way around using the drywall knife between the flat bar and the cabinet for protection. Some of these have a ridiculous amount of nails. Take your time!
sixeightten is offline   Reply With Quote
Old 05-31-2012, 01:10 AM   #4
You can cut the top into 2' x 2' sections while it's still on the cabinets and just remove small portions at a time. Takes less force and patience...
Jrrckd is offline   Reply With Quote
Should I remove tile floor after minor flood? dan1980 Flooring 5 05-24-2012 03:48 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
New countertop, sink and faucet darlenep Project Showcase 4 08-17-2008 09:33 PM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 04:39 AM
Countertop sink hole Grebus Remodeling 1 08-31-2005 10:09 PM
