Remove Tile? Tub? For Refurb A Bathroom? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 12:47 AM   #1
Remove tile? Tub? For refurb a bathroom?
Hi, I want to have my wife's bathroom redone, She wants to just put a tub insert over the existing tub and put up a fiberglass wall system over the existing tile, i told her that it's better to first off, just replace the tub with a totally new one, and remove the tile on the wall before installing any kind of fiberglass walls. What way would be the best all around way to do it? Also, I want to have the floor tiled with a slate tile with in floor heating. Is there a better type of tile to use that's not to slippery when wet with in floor heating ? It's not a huge bathroom, about 10' by 6' wide. Thanks so much, mjclemm..
Mjclemm is offline   Reply With Quote
Old 07-08-2012, 10:21 AM   #2
Rewards Points: 17,884
A lot depends on how long you expect to keep the home.
In order to replace the tub the walls would have to be gutted down to the studs and all be redone.
I'd never ever install an enclosher over old tiles.
I also would never install slate in a bathroom, it's one of the most poris, stain prone, and brittle tiles you can use. There's tons of tiles out there with a slight texture.
Old 07-08-2012, 10:28 AM   #3
Renovations contractor
Bonzai's Avatar
Done lots and lots of slate tile bathrooms and showers ... Very common here especially in a lot of the higher end homes. Needs about 3 coats of sealer.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Help! Tiling over tile in bathroom Seth M Flooring 3 04-05-2011 10:25 AM
Bathroom Renovation-To Tile or not to tile jte1130 Remodeling 7 04-14-2009 10:39 AM
Remove hardwood for tile headcrash0101 Flooring 5 06-23-2008 02:21 PM
