Removal Of Metal Shower Drain From Above - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-15-2016, 06:30 PM   #1
Rewards Points: 6
Removal of Metal Shower Drain From Above
Our second floor shower is leaking and we have discovered the cause: cracking in the rusted out shower drain. I have ordered a Wingtite shower drain as a replacement, but must first remove the existing metal shower drain.
I do not have a fancy power saw to cut through the metal drain to remove it in pieces from the shower floor. Does anyone have any recommendations on how to remove the metal drain without damaging the PVC pipe it surrounds?
I have tried / am trying to chip away at the silicon sealant around the outside of the metal drain with the hopes of just popping it out at some point. But before I do too much damage to the shower floor and/or the metal drain, I wanted to ask for some advice on how to best remove the drain and to find out if anyone has had any experience doing this. I have included two pictures of the shower drain from above.
The pictures don't show it, but there is about 3/4" between the top lip of the metal drain and the top lip of the PVC pipe.
jreddiv is offline   Reply With Quote
Old 05-15-2016, 06:31 PM   #2
Rewards Points: 6
Re: Removal of Metal Shower Drain From Above
Picture 1: https://goo.gl/photos/wkzReVP5yDWV9tCPA
Picture 2: https://goo.gl/photos/ck27L4AEWtSD9yeS9
Old 05-16-2016, 11:15 AM   #3
Rewards Points: 38
Drain must be removed from the bottom and the new drain installed from the bottom. If that is a problem you have to do it anyway.
SHR Plumber is offline   Reply With Quote
Shower Drain Holes Stripped azcycle Plumbing 11 03-05-2018 04:10 PM
Help: Sewage smell coming from shower drain! erikerikerik Plumbing 23 01-11-2014 02:09 AM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
