Remodeling My Kitchen - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2011, 11:09 AM   #1
remodeling my kitchen
Hello Im remodeling my kitchen andd all my walls are plaster with cinder block behind it
I plan on using tapcons 1/4 x 2 3/4" the plaster is built out 3/4" covering the block will my tapcon be good or is it over kill thks for your input
wop1tfl is offline   Reply With Quote
Old 08-24-2011, 11:28 AM   #2
Retired Moderator
Rewards Points: 7,174
What are you using the tapcons for?
Old 08-24-2011, 11:51 AM   #3
To hold the cabinets up there are no studs at all so i was gonna pre-drill the cabinet then drill into the block and fasten the tapcon
Old 08-24-2011, 11:54 AM   #4
I didnt think anchors would work the next options is toggle bolts
Old 08-24-2011, 12:48 PM   #5
Retired Moderator
Tapcons will work---It would be better to open the drywall and put in a nailer but the Tapcons you described will work---They are not the best with cinder block so plan on a few that won't grab.
Old 08-24-2011, 09:17 PM   #6
Ok cool thanks for your input
The Following User Says Thank You to wop1tfl For This Useful Post:
oh'mike (08-25-2011)
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
kitchen and bathroom remodeling Grumpy Remodeling 11 02-10-2005 01:35 PM
