Reframing An Existing Wall With Plumbing - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-25-2015, 09:54 PM
Reframing an existing wall with plumbing
A question I think I know the answer too and I'm just looking for confirmation. We need to reframe a wall (not load bearing) shared between the bathroom and laundry room. This wall has a vent pipe and all the water lines for shower/toilet/vanity. Do I have a plumber come in and remove all the piping and cap it off, remove poorly framed wall, reframe wall correctly and then have the plumber come back in to rerun new plumbing? The plumbing also needs to be replaced regardless of the walls condition. Am I on the right track?
Bugzz is offline
Old 06-26-2015, 01:05 AM
Rewards Points: 6,652
It needs to be a 2x6 or 2x8 wall. That way you have enough "meat" on the bottom & top plates, when you put in the drain lines for the laundry & shower, toilet & sink.
If you have a basement, you need to place another joist on the other side of the DWV where it goes through. That way you have enough support, if you have to cut one of the joists to install the tub or shower drain.
When they built our house, they put the two joists around 6" apart. That way the tub drain trap can set properly just below the sub-floor. I have a picture somewhere in my history, that shows how they did my joists. I may also have one somewhere showing the Cast Iron riser for the main house vent.
gregzoll is offline
Old 06-26-2015, 07:41 AM
Rewards Points: 17,890
Post a picture of this wall when you can.
What type plumbing is it your dealing with?
Slab, crawl space, basement?
What's wrong with the way the walls framed now?
There may be an easier way to do this.
joecaption is offline
Old 06-26-2015, 07:51 AM
Plumber
TheEplumber's Avatar
Rewards Points: 706
If the plumbing needs replaced, I'd remove it first- then frame. Also, ask the plumber if your proposed stud layout works with the new plumbing work.
He can then drill through the new studs
TheEplumber is online now
Old 07-13-2015, 08:36 AM
Rewards Points: 173
If the plumbing all runs vertically then it should be pretty simple. If any pipes run through the studs horizontally then things will get a little trickier.
If all the plumbing is going to be replaced anyways, just rip it out, rebuild your wall, then install the new plumbing.
MrBryan is offline
Stud in middle of tub/shower plumbing wall. CharlieR Plumbing 2 11-06-2012 03:07 PM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Anchor a concrete curb wall to an existing slab Simon96Taco Concrete, Stone & Masonry 6 10-03-2012 05:17 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
