Recovering Floor Vinyl Stuck To Wall For Backsplash - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By jlhaslip
  • 2 Post By Yodaman
  • 1 Post By joecaption
  • 1 Post By Yodaman
Old 12-30-2017, 11:08 AM   #1
Rewards Points: 12
Recovering floor vinyl stuck to wall for backsplash
The previous owners thought it would be a good idea to use a some scrap vinyl from the floor to create a backsplash and to cover the window sill and the area below it. I'd like to made this disappear, but it's not coming off without taking some drywall with it. I'm not up for replacing the drywall. I'm wondering if thinset tile would work over the top?
Any other thoughts?
mkirkwag is offline   Reply With Quote
Old 12-30-2017, 11:21 AM   #2
Property Mgt/Maint
Rewards Points: 6,368
Re: Recovering floor vinyl stuck to wall for backsplash
A oscillator tool with a scraper attachment will take it off without destroying the base.
Yodaman is offline   Reply With Quote
Old 12-30-2017, 11:34 AM   #3
Rewards Points: 12
OK, thanks. If I can't find a way to cover it that works, I'll look into that. I'm not a dedicated DIYer, so I don't have the tool and would need to buy it.
Old 12-30-2017, 02:45 PM   #4
jlhaslip's Avatar
Rewards Points: 708
Add some heat from a hair dryer will help.
Many glues are heat sensitive.
ChuckF. and CrazyGuy like this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 12-30-2017, 03:56 PM   #5
Property Mgt/Maint
Once you have the tool for awhile you will wonder why hadn't bought one sooner. So many tasks made easier that involve cutting, scraping and sanding.
joecaption and Mike Milam like this.
Old 12-30-2017, 04:49 PM   #6
Rewards Points: 17,890
What's the plan once it's removed?
No matter what tool you use there's going to be damage to the sheet rock.
mkirkwag likes this.
Old 01-01-2018, 03:14 PM   #7
Rewards Points: 12
Hi, joecaption. It seems that my question wasn't as clear as it could have been. I don't want to remove it at all. What I meant to ask was whether or not thinset would stick to the vinyl so I could lay tile over the top. Alternately, I was interested in other (easy) effective ways to cover it.
I'm not much of a DIY person; I don't want to start a major project but a few minor projects are okay with me.
Old 01-01-2018, 10:15 PM   #8
Rewards Points: 1,744
You can also try a clothes iron, an old one if available. Experiment to find a heat setting that will soften the glue without melting the vinyl. Heat it up, and quickly peel.
ChuckF. is offline   Reply With Quote
Old 01-02-2018, 07:02 AM   #9
Property Mgt/Maint
Thin set is not going to stick very well to vinyl. The best choice is to get the vinyl off. Hire some help if needed.
mark sr likes this.
Old 02-11-2018, 07:03 PM   #10
Rewards Points: 12
OK, thanks. Not in the cards, so I'll just leave it.
Tags
backsplash , bathroom , vinyl on wall
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
