Recommendation For Bathroom - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-16-2019, 12:44 PM   #1
Rewards Points: 256
Recommendation for Bathroom
I am not sure what was installed (see photo.) I donít want to remove the clamps and risk damaging the tile.
Is there anything I can install such as a wash rack or shaving/cosmetic tray that will work with the already installed clamps?
ken33xx is offline   Reply With Quote
Old 03-16-2019, 01:35 PM   #2
Rewards Points: 834
Re: Recommendation for Bathroom
That tile looks pretty generic...surely you could find some replacement pieces if you bust something.
huesmann is offline   Reply With Quote
Old 03-16-2019, 01:40 PM   #3
retired painter
Rewards Points: 826
Those 'clamps' should be screwed into the wall. The odds are the only damage you'd do removing them is exposing the screw holes in the tile.
mark sr is offline   Reply With Quote
Old 03-16-2019, 01:41 PM   #4
Rewards Points: 256
O.k. but if possible I would prefer to install something.
Old 03-16-2019, 02:02 PM   #5
Rewards Points: 542
Remove brackets, install mirror.
Let it Snow is offline   Reply With Quote
Old 03-16-2019, 02:18 PM   #6
Rewards Points: 256
Yes, three do appear to be screwed in and can be removed.
However, I have no idea whatís going on with the one in the lower area.
Any thoughts on to get this off?
Old 03-16-2019, 02:39 PM   #7
retired painter
Rewards Points: 826
That looks like someone's attempt at a patch.
Old 03-16-2019, 02:50 PM   #8
Rewards Points: 256
Yes, I think your right.
It appears to be some type of plastic putty.
Any idea of what can be done? Maybe cut it off assuming the putty isn't covering anything metal.
Old 03-17-2019, 05:54 AM   #9
retired painter
Rewards Points: 826
I'd try cutting it off, a multi tool should work well although a chisel should also work. Just take it slow until you know how it will go! As long as you don't crack the tile it's not like you will make it look worse.
Old 03-17-2019, 10:05 AM   #10
Rewards Points: 834
I'd try heating it up with a heat gun first, see if it's the type of goop that becomes pliable with heat. Maybe you can just pry or scrape it out.
Recommendation for Malware Protection justplumducky PC Repairs & Upgrades 32 01-26-2017 07:36 AM
Tile scoring recommendation bryanp22 Flooring 1 05-14-2013 10:09 PM
Recommendation on Sewage Pump Mrs13 Plumbing 0 04-04-2013 01:36 PM
Need Bench Vise Recommendation blincoln Tools 10 04-28-2012 08:59 AM
Fish tape recommendation? dataguy Electrical 17 11-05-2011 11:49 PM
