Re-glue Formica? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-22-2015, 06:58 PM   #1
PPBART's Avatar
Rewards Points: 1,243
Re-glue Formica?
I've recently completed a couple of small cabinets with Formica tops for my daughter. I was at her house this morning and noticed that a couple of inches of the edging at one rear corner of the top has apparently somehow been pulled loose -- maybe snagged by the kids somehow(?) It's not very obvious as it's still tight against the edge. How can I repair this to prevent any further damage? Can I just insert a bit of rubber cement to reglue it?
PPBART is online now   Reply With Quote
Old 06-22-2015, 07:23 PM   #2
Property Mgt/Maint
Rewards Points: 6,368
if they are the pre-cut ends that go along with a purchased counter top, and were originally installed with a iron, you may be able to re-heat them to re-attach.
If not, try a hot glue gun
[political signature removed]
Yodaman is offline   Reply With Quote
Old 06-22-2015, 09:53 PM   #3
PPBART's Avatar
Originally Posted by Yodaman View Post
if they are the pre-cut ends ...
Not the pre-cut ends. These were cut to fit the edges of the top.
Old 06-22-2015, 09:56 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,486
Preglue or not, it may still work with the HPL glue, if not the hot glue should work as suggested.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Need exterior glue advice mske390 Carpentry 7 06-25-2015 09:16 AM
Sistering beam question, what outdoor glue? maxim1 Building & Construction 12 07-11-2014 05:29 PM
carpet glue pfmartin0387 Flooring 1 10-03-2010 08:17 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 10:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 02:16 AM
