Range Hood Vent Downward Direction Ok? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-01-2014, 09:23 PM   #1
Rewards Points: 248
range hood vent downward direction ok?
Can a 3.5" x 10" range hood vent slope downward, approx 35 degrees for about 3 feet, before exiting out of the side of a house through a range hood vent cap?
jackwashere is offline   Reply With Quote
Old 01-02-2014, 01:34 PM   #2
K&B Designer
Live_Oak's Avatar
You will most likely get condensation from the moisture that will drip back down the vent and into the vent screens or baffles. The best choice is always straight up and out. Or up and a 90 to go out.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 01-02-2014, 09:32 PM   #3
Rewards Points: 248
No I'm fine in that respect. I need to go up and a 90 then another 90 then down then out.
Old 01-02-2014, 09:34 PM   #4
Rewards Points: 248
By the way, I was more concerned about if it is ok with the codes.
Venting a microwave range Hood over the existing vertical vent out gnans Kitchen & Bath Remodeling 0 05-31-2012 09:38 PM
range hood vent vinman Roofing/Siding 6 05-07-2012 01:23 PM
Range Hood Vent Light Switch mrduke Appliances 0 05-21-2011 06:10 PM
range hood ventilation Millertyme Appliances 0 08-31-2010 07:31 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
