Range Hood Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-18-2015, 10:45 PM   #1
Rewards Points: 6
Range Hood Install
I bought a home which has no range hood (part of the deal). I asked a contractor for a quote to install range hood and he said, it will be 130-150. Is this a fair labour charge?
amitdi is offline   Reply With Quote
Old 06-19-2015, 01:43 AM   #2
Rewards Points: 144
You don't say what part of the country your in but yes it is a fair price most anywhere.I't a small job that won't take long but he still has to show a profit and drive there and possibly leave another job to take care of this one.
I always get a kick out of customers that say"you can do this one on your way home after hours".
There are no after hours.If I'm working it's working hours no matter what the watch says.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
amitdi (06-19-2015)
Old 06-19-2015, 04:55 AM   #3
Retired Moderator
Rewards Points: 7,174
Has that fellow seen the house?
Was there ever a hood in the house?
is the ductwork in place? Electrical?
Need more info.
Old 06-19-2015, 05:41 AM   #4
Rewards Points: 107
Might be a fair charge if he is replacing an existing one. For any work that I have had done, this wouldn't even cover the electric circuit. Then you have ducting and the actual install on top of that .
jimn01 is offline   Reply With Quote
The Following 2 Users Say Thank You to jimn01 For This Useful Post:
amitdi (06-19-2015), oh'mike (06-19-2015)
Old 06-19-2015, 05:59 AM   #5
Retired Moderator
Some of the new hoods are huge--8" ducts are common---and 14amp draw--
Like I said before--more info needed
Old 06-19-2015, 09:01 AM   #6
Rewards Points: 6
Theres no hood there, right now. Its a 30" wide space. He saw the house, the vent outlet is in place. This quote is assuming he will use this outlet. He mentioned that he will check if it goes up, if not, then he will let me know before doing additional work.
There is an electric plug, but not sure of anything else. There was a microwave hood before, but the previous owner took it away. I am in Winnipeg.
Old 06-19-2015, 09:53 AM   #7
ZZZZZ's Avatar
Rewards Points: 2,158
I recently installed a range hood in my remodeled kitchen.
Not that it's complicated, but my bad luck, there was a wall stud right smack in the middle of the 30" wall opening. Fortunately I hadn't put up the drywall yet, so I could reframe around the new vent opening.
Make sure there isn't a stud back there in your wall.
ZZZZZ is online now   Reply With Quote
Old 06-20-2015, 06:00 AM   #8
Retired Moderator
If the workman saw the project and gave you that price, I think you both have a deal---
Sure sounds like a fair price.
Wire outlet's cable inside range hood juravel Electrical 5 05-28-2014 11:51 PM
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
fantech outside mounted range hood fan carpdad Appliances 0 11-29-2012 12:29 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 04:59 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
