Raising A Dropped Ceiling - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-03-2014, 11:41 AM   #1
Raising a dropped ceiling
We have a single-story home, built in 1962, and the ceilings are lower in both the full and half bathroom. The rest of the house is at 8ft, putting the bathrooms at 7ft. Also, the bathtub is sunken in to the floor about 6-8in, perhaps to accommodate a low ceiling?
We are about to gut and remodel the the full bath and would like to raise the ceiling/level-out the tub, but we don't know if there is a good reason the developers made these homes this way and if we should just leave it. We can touch the ceiling and when we push on it there is some flex.
Does anyone have experience with this situation? Is raising a ceiling more trouble than it's worth?
meganmae is offline   Reply With Quote
Old 07-03-2014, 12:20 PM   #2
Retired Moderator
Rewards Points: 7,174
Time to do some investigating---if accessible from the attic--find out why the ceiling is lowered---
If not--cut into the ceiling and figure out what's hiding up there---most things can be moved---air ducts ,however, are a major problem to move--cross your fingers---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (07-03-2014), meganmae (07-06-2014)
Old 07-03-2014, 12:34 PM   #3
Rewards Points: 202
Are there fans that are vented through the exterior walls in these areas? Seems like a lot of work compared to simply going through the roof, but I have seen a few like that where this appeared to be the only rationale.
The Following User Says Thank You to DexterII For This Useful Post:
Old 07-06-2014, 09:11 PM   #4
There are no air ducts running through the space. We assumed the ceiling was lowered so steam from the shower wouldn't collect and would instead flow out through the window/door. There is fan that was installed long after the house was built so we can't find any good reason to keep it so low. My main concern is running in to a can of worms if we start cutting up the ceiling. I suppose we can just go for it and hope we don't end up with an expensive learning experience. Thanks for the feedback.
Tags
bathroom , ceiling , renovate
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 12:58 PM
Raising ceiling, using rafter ties cibula11 Building & Construction 23 01-20-2010 06:38 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
raising ceiling famtwp Building & Construction 10 05-30-2007 08:00 PM
raising ceiling strada23 Building & Construction 5 05-06-2007 10:12 PM
