Raising Bulkhead - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2014, 10:13 PM   #1
Rewards Points: 54
Raising bulkhead
Demoed the shower stall today and I want to raise the bulkhead. It appears the cavity above the shower goes directly into the attic as I took a broom handle and shoved it up much higher than the ceiling. I'm hoping I can do this without a lot of blown insulation falling down and I also am hoping not to have to go into the attic. Advice?
kripes is offline   Reply With Quote
Old 11-24-2014, 04:43 AM   #2
Retired Moderator
Rewards Points: 7,174
You will be a better man than me if you can do this without a trip to the attic---
There is no magic way to keep the insulation up there---I don't try any more---just pull it out--save it if it's clean or dump it.
Just thought why I don't try--I almost always add a new exhaust fan/light combination above the tub/shower--and use the open ceiling to access the attic for the wiring/duct work----then replace the insulation with R-38 faced batts---
Old 11-24-2014, 06:33 PM   #3
Rewards Points: 54
Thanks, that was clear enough. Ah well at least it's not the dead of summer. That's a good tip about the fan, but I got that done last year. Another thing I could do is put a light in the shower.
So the only trip to the attic is to replace the insulation I removed at the end of it all, correct?
Old 11-24-2014, 06:57 PM   #4
Retired Moderator
Yes===do every thing you can from below--you could even staple up batts of insulation,if you wish--
Old 01-02-2015, 12:54 PM   #5
Rewards Points: 54
December got busy so I'm actually doing this tomorrow. I just read your reply and actually that is the idea my friend and I had -- put bats on top of a piece of plywood. Screw the plywood to the attic joists. Screw the piece of cement board to the plywood.
Old 01-02-2015, 02:36 PM   #6
Rewards Points: 144
Skip the plyoood.Get faced batts and staple them to the joists.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (01-02-2015)
Old 01-02-2015, 02:51 PM   #7
Retired Moderator
No need to invent an overly complicated solution---dry wall is fine for the ceiling==and will hold tile ,if that is your intention.
Old 01-02-2015, 04:09 PM   #8
Rewards Points: 54
Thanks for the prompt replies, very helpful. I did not know about faced batts...that looks like a good solution. I'll do drywall then.
Drywalling bulkhead and wall repair after basement reno Simon96Taco Drywall & Plaster 9 11-22-2013 10:38 PM
Drywalling bulkhead and wall repair after basement reno Simon96Taco Drywall & Plaster 0 11-21-2013 01:28 AM
Bulkhead Drainage Concern Enigma007x Landscaping & Lawn Care 2 09-04-2012 08:15 AM
Increasing height of Steel Bulkhead Concrete Foundation ulrichfolkers Concrete, Stone & Masonry 5 06-18-2012 09:40 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 09:24 AM
