R&R Quartz Countertop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2015, 12:10 AM   #1
Rewards Points: 866
A newly laid quartz countertop needs to be removed so as to enable the correct removal and installation of a very heavy and expensive porcelain sink. Can this be done so that the same countertop can be reinstalled?
Klawman is offline   Reply With Quote
Old 09-09-2015, 05:33 AM   #2
Retired Moderator
Rewards Points: 7,174
Usually---depends on the original install--is it one piece or is it an L with a glued in section?
Old 09-09-2015, 11:10 AM   #3
Rewards Points: 866
It's an "L" comprised of two pieces of quartz meeting at the bend of the "L".
Old 09-09-2015, 06:42 PM   #4
Rewards Points: 866
Or by an "L did you mean a top with a second piece glued around the rim so as to make an apron. This hides the plywood top and makes the slab appear to be twice as thick.
Old 09-09-2015, 07:30 PM   #5
Rewards Points: 5,348
So there was a change in sink choices.
It adds a level of difficulty to the job.
Removal of an "L" shaped stone top is tricky.
Success depends on competence.
Ron
B. Franklin 1759
Old 09-09-2015, 07:43 PM   #6
Rewards Points: 866
No change. Just a crappy installation.
Old 09-09-2015, 09:34 PM   #7
So this sink can't be lowered into the sink base and be removed?
Ron
B. Franklin 1759
Old 09-10-2015, 07:58 PM   #8
Rewards Points: 866
Lowering the sink into the base isn't a problem. Installing it with the countertop already down is. The contractor and its sub finally realized the same and agreed to remove the top, which isn't so difficult since it is freshly laid but will become all the more difficult as the adhesive cures over time.
Old 09-11-2015, 09:52 PM   #9
Rewards Points: 866
The countertop was removed without damage in about 10 minutes.
The Following User Says Thank You to Klawman For This Useful Post:
oh'mike (09-11-2015)
Old 09-11-2015, 10:52 PM   #10
Retired Moderator
Glad it worked out----I hate redoing work----
Klawman (09-12-2015)
Old 09-12-2015, 01:51 AM   #11
Rewards Points: 866
You didn't hear the half of it.
Old 09-12-2015, 05:43 AM   #12
Retired Moderator
I used a counter top outfit that was unusually good---the installers and fabrication crews were real pros.
They told me the owners standard policy was to replace a top if it could not be fixed to the buyers satisfaction after one service call.
I'm not using that outfit any more--that to is a long story.
Old 09-12-2015, 11:41 AM   #13
Rewards Points: 866
The general had a real problem here. Before I bought this non-returnable sink I gave it the installation instructions and flagged the caveat for it about the need for a custom support to be made by a good cabinet maker. They told me they new how to do it, but then they sublet the job and failed to supervise.
Old 09-27-2015, 01:15 AM   #14
Rewards Points: 866
Update. The contractor ended up having the countertop removed, a newone cut, and then reinstalled the sink (but it still did it their way and not as per the manufacturer's installation instructions). So far it is cracking in three places.
oh'mike (09-27-2015)
Old 09-27-2015, 08:17 AM   #15
Retired Moderator
Arg-----You are having a lot of problems with your contractor and his subs----
I would have thought the contractor would have found a good counter top outfit if he's been doing that sort of work for a while----I wonder what is going on?
Is he new or to easy on accepting mediocre work? Or goes with an inexpensive outfit hoping to get high quality?
Island quartz countertop problem vela Kitchen & Bath Remodeling 0 06-29-2012 02:20 AM
quartz countertop installation kcasey Kitchen & Bath Remodeling 6 03-31-2012 10:03 AM
quartz countertop problem mmmac Building & Construction 9 12-24-2010 06:04 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 08:05 PM
Plywood under quartz countertop? kbrinton Remodeling 5 04-11-2008 08:04 PM
