Question On Hanging Kitchen Wall Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-28-2014, 09:07 PM   #1
ZZZZZ's Avatar
Rewards Points: 2,154
Question on hanging kitchen wall cabinets
I'm in the process of remodeling the kitchen and have a question about how best to hang the wall cabinets.
All of the cabinets are being moved from their original positions which were along two interior 2x4 16" OC studded walls (which have been demo'd to create an open kitchen.)
The house has 2x6 exterior walls with 24" OC studs and the cabinets will go onto that wall. Two of the cabinets are 30" and 36" wide, and they have to be arranged on the wall such that there is only one stud behind these two cabinet to screw into.
How do I handle this? Is screwing the cabinets into only one stud (at the top and bottom of the cabinet) sufficient? Is screwing these cabinets into the sides of the adjacent cabinets going to provide enough support?
Or do I just install a couple of more 2x6 studs into the exterior wall where needed to provide supports? There is no drywall up on the walls now so I can do this without a problem.
Thanks, and any other suggestions/recommendations are welcome.
ZZZZZ is online now   Reply With Quote
Old 12-28-2014, 09:59 PM   #2
Rewards Points: 996
put blocking between the studs. about where the srews would go.
Fix'n it is offline   Reply With Quote
The Following 2 Users Say Thank You to Fix'n it For This Useful Post:
joecaption (12-28-2014), ZZZZZ (12-28-2014)
Old 12-28-2014, 10:09 PM   #3
Davejss's Avatar
Rewards Points: 894
Yup. That's exactly what you should do. With your wall opened up you have the chance to place horizontal blocking everywhere you need to.
Davejss is offline   Reply With Quote
Old 12-28-2014, 10:23 PM   #4
Rewards Points: 996
and a chance to do all the wiring. undercab light wires.
Old 12-28-2014, 10:36 PM   #5
ZZZZZ's Avatar
Thanks guys. I was thinking vertical when I should have been thinking horizontal. Blocking it shall be.
Old 12-28-2014, 10:36 PM   #6
ZZZZZ's Avatar
Wires already in place.
The Following User Says Thank You to ZZZZZ For This Useful Post:
oh'mike (12-29-2014)
Old 12-29-2014, 11:46 AM   #7
Rewards Points: 5,694
Or, preferrably, exactly where the screws would go!
jeffnc is offline   Reply With Quote
Old 12-29-2014, 07:53 PM   #8
Rewards Points: 996
yeah, there ya go, get'n all technickel and stuff
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Hanging Kitchen Cabinets ryanb4614 Carpentry 6 12-24-2011 01:26 AM
Wall too short for cabinets - more info, more questions Annie5 Carpentry 46 11-30-2009 09:16 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 09:34 PM
