Question About Kerdi Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Guap0_
Old 12-12-2018, 08:02 AM   #1
Rewards Points: 140
Question about Kerdi shower
I'm building my first Kerdi shower in a house I'm currently renovating. I have the Kerdi panel walls up, and will soon be ready to put in the bench, pan, and curb (all Kerdi). The ceiling in the shower is 10 feet. It's just occurred to me that I won't be able to simple put any ladder or stool on top of the Kerdi pan to tile up high, as it would presumably damage it. What's the best option here? I assume there's a method people use in this situation; I've just never had to think about this.
JWindmill is offline   Reply With Quote
Old 12-12-2018, 08:20 AM   #2
Guapo
Rewards Points: 11,950
Re: Question about Kerdi shower
I think that if you lay a piece of plywood over the shower pan first, there shouldn't be a problem.
firehawkmph and JWindmill like this.
Guap0_ is offline   Reply With Quote
Old 03-12-2019, 04:11 PM   #3
Rewards Points: 368
what did you end up doing? I have been trying to get as much info on this install as possible because I am doing this for the first time in a few weeks time.
I have seen them use kerdi board that is like 2-3 in thick and mortar to build a bench then just water proof the seams and tile it as you would any other bench.
JPeters is offline   Reply With Quote
Old 03-13-2019, 08:02 AM   #4
Rewards Points: 140
I used a piece of plywood and stuck pieces of cardboard under it at the corners. My bench was a prefab Kerdi.
Old 03-13-2019, 03:54 PM   #5
Rewards Points: 368
do you have any pics of your kerdi build? I'm trying to do a soakertub, curbless shower, double sink, toilet and master closet in a 14x8 area.
Old 03-14-2019, 12:07 PM   #6
Rewards Points: 140
I don't have any pictures of the Kerdi before tile. Shower is in a tough spot to get much of a picture. I used Kedrdi board, bench, curb, niche, and pan. It was definitely a breeze compared to concrete and cement board. The peace of mind is nice too.
Old 03-14-2019, 04:01 PM   #7
Rewards Points: 368
did you do the kerdi on a wood sub floor? Do you have pics? I want to do the same thing. I want to add a bath tub to the kerdi curbless shower area. as well as heated floors.
Old 03-15-2019, 11:29 AM   #8
Rewards Points: 6,370
Putting plywood down isn't a great option if the plywood is thick, because even with cardboard it could dent the raised edges and corners of the pan. You could do a couple layers of something like luan. That way there is enough total thickness to protect, but each layer is actually thin enough to bend and conform to the shape of the pan without denting it.
However I avoid this problem by simply tiling the floor first. You would want to do this anyway because the wall tiles should overlap the edges of the floor tiles for the best look. Also, the floor tiles support the wall tiles (using a correct size tile spacer) to give the right grout joint size. This approach fixes all problems. Once the floor is hard, you can stand on it or put a step ladder on it.
jeffnc is offline   Reply With Quote
Old 03-15-2019, 06:20 PM   #9
Rewards Points: 140
The plywood concerned me, so I checked on it a few times. Worked out well for me. I considered doing the floor first, but find it easier to do it last. Then the first row of tile after the floor.
Old 03-20-2019, 03:38 PM   #10
Rewards Points: 368
what was the approximate cost for the kerdi materials?
Old 03-29-2019, 04:35 PM   #11
Not sure what you were trying to say, but this is basically an oxymoron
Old 03-29-2019, 04:35 PM   #12
A standard shower kit that contains all the parts you need is roughly $500.
Shower Tile with Schluter Kerdi System tstorm Tiling, ceramics, marble 7 10-03-2017 08:45 PM
Quick question: shower drain gaskets MANGINA Plumbing 8 09-08-2012 08:32 PM
beginner's question about shower fixtures diy'er on LI Plumbing 6 02-19-2012 11:05 PM
Basement Shower Remodel Question mdsnj Kitchen & Bath Remodeling 3 02-27-2010 01:16 PM
Shower Arm Question brakea Plumbing 2 01-02-2009 06:58 PM
