Preparing Stud Tubwalls For Ceramic Tile - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2010, 01:53 PM   #1
Question
Preparing stud tubwalls for ceramic tile
I ripped out the walls out of my son's moisture damaged bathtub bay and now I have to fix it. The adjacent walls are all sheetrock with calcoat (total one inch thick). I'm starting with bare studs.
I plan to put up plain 1/2 inch sheetrock, covered with 4 mil plastic sheeting (stapled on), then Durock screwed on, then adhesive and ceramic tiles.
I am cutting all adjacent sheetrock/calcoat with an angle grinder with metal cutting blade, to make the edges straight and cut out the metal mesh in places.
How far up should I go with the Durock? Would it be better to go all the way to the ceiling for moisture protection when showering? How far up should I put the ceramic tile?
Thanx so much for your time!
Tudy
Tudy is offline   Reply With Quote
Old 07-08-2010, 02:30 PM   #2
Handyman
Rewards Points: 520
Tudy
What are you trying to acheive with the 1/2" drywall? The Duroc can be installed directly onto the studs.
Angle grinder works well for the mesh but the dust must be incredible...I usually use a sawzall (which is dusty enough)
Wherever you put tile is where you want the Duroc. It's personal preference really. I have installed up to various heights. Usually, If you want a tile ceiling you would tile right up the wall. If you Duroc with no tile you will have to skim coat for a smooth surface.
canadaclub is offline   Reply With Quote
Old 07-08-2010, 03:15 PM   #3
As I mentioned, I am trying to match up to the original bath wall, which is sheetrock with calcoat plastered over it, about one inch thick, total. What is a sawzall? Is it a recipricating saw?
Old 07-08-2010, 04:45 PM   #4
Rewards Points: 101
yes it is.
Axecutioner-B is offline   Reply With Quote
Old 07-08-2010, 07:12 PM   #5
Unhappy
So, is this an ok procedure or not?
1- plain sheetrock over studs
2- 4 ml plastic sheeting stapled over plain sheetrock
3- Durock screwed over plastic & plain sheetrock
4- adhesive, then ceramic tile
Again, I need the extra half inch to match up to the rest of the original half inch sheetrock with calcoat over it.
Any better ideas? Thank you for your help!
Old 07-08-2010, 08:18 PM   #6
Retired Moderator
Rewards Points: 7,174
I suggest that you use 1/2 inch furrings strips---NO DRYWALL in the shower area--
If you have access to a table saw -you can make the strips exactly as thick as you need.
Why put any thing that can get moldy and dissolve behind the Durrock?
Old 07-08-2010, 09:53 PM   #7
Talking
Thank you so much! Would the plastic sheeting over the furring strips help waterproof the wall? I think I read it somewhere on this forum, that it was a good idea. Just wanted another opinion. Thanx.
Old 07-09-2010, 05:13 AM   #8
Retired Moderator
I do not put plastic behind the Durrock. If you are concerned with waterproofing----Use Hydroban
by Latactete or perhaps red guard.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Preparing to tile in bathroom. Questions HenryG Flooring 34 02-22-2010 02:41 PM
Install glass tile on wood stud pole (for support beam) chatelain Remodeling 1 06-21-2009 10:45 PM
Preparing wood subfloor for ceramic tile Schwarzaroo Flooring 2 01-12-2009 05:31 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
