Possible Botched Shower Enclosure Installation. Help!! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-20-2015, 12:07 AM   #1
Rewards Points: 12
Possible botched shower enclosure installation. Help!!
Folks....I'm a first time poster. This isn't exactly do it myself but I'm looking for advice from people who know this stuff and I have been lurking in the forum and see a bunch of folks who hopefully can advise me here.
I hired a local contractor with a very good reputation to gut and remodel my bathroom. Everything looks fine except for one major thing that is really bothering me. They are using swanstone for the shower enclosure. Ceiling and three walls. Everything looks good except for the bottom left portion near the floor of the wall where the shower controls will be.
They glued the swanstone to a plywood sheet. The bottom of the swanstone is not making contact with the wood because the lip of the shower pan is there. That tells me they measured something wrong. Why didn't they just add a thicker piece of plywood?
I am attaching a photo of what I am describing. I had a guy over the other day who is going to install frameless glass doors. He wasn't too thrilled about the problem but said he could get a door in to work fine.
The main contractor said, "this is very common" and "it happens all the time" and it's "not a problem". Somehow I don't believe it happens all the time.
What do you folks think of it?
Pleashelpme is offline   Reply With Quote
Old 01-20-2015, 12:12 AM   #2
Rewards Points: 12
Here is another picture of it.
Old 01-20-2015, 12:24 AM   #3
Rewards Points: 12
Dog gone it. It looks like I should have posted this in the kitchen and bathroom remodeling forum. Can it be moved? Sorry. I'm brand new here.
Old 01-20-2015, 02:08 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
THAT - DOES NOT "happen all the time".
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Pleashelpme (01-20-2015)
Old 01-20-2015, 03:11 AM   #5
Retired Moderator
Rewards Points: 7,174
Moved this for you.
Old 01-20-2015, 03:14 AM   #6
Retired Moderator
Beginner mistake---I would not accept that.
Old 01-20-2015, 09:53 AM   #7
Rewards Points: 107
He needs to redo that. It's wrong, ugly and a water leak waiting to happen .
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
Old 01-20-2015, 11:06 AM   #8
Rewards Points: 12
I just called the installer. He said he would rip it out and fix it. When I first mentioned it he made like he didn't know what I was talking about. Once I told him I had some professional builders look at it and that they told me it was a "rookie" mistake he said, "OK, we'll fix it". He didn't sound happy.
I'm paying good money for this. Why should I accept anything but perfect work?
Old 01-20-2015, 12:05 PM   #9
Retired Moderator
You are not being unreasonable asking for professional work from a professional installer---the work should be right---that is just expected---and paid for.
Glad to hear they are going to set it right--keep us informed---
Old 01-20-2015, 12:09 PM   #10
Rewards Points: 12
You folks have been terrific. I don't know what I would have done without you.
By the way. Here is a wider shot of the wall.
Old 01-20-2015, 12:58 PM   #11
Retired Moderator
I see that the wall is not tight to the shower pan--the drywall should have covered the left hand edge if it was----
My guess---pan needs to be tight to the framing --the plan was to use 1/2" plywood to back the Swanstone---the ply flush to the drywall--and over the flange of the pan--allowing the Swanstone to go over the flange.
Simple fix---fur out the studs so the ply backer is positioned correctly---
If that is the mechanical wall--be sure the mixer valve is far enough out to compensate for the thicker wall---
Old 01-20-2015, 02:49 PM   #12
Electrician/DIY fanatic
Vegas Sparky's Avatar
Rewards Points: 606
I'd have them pull that little bit of drywall, and bring the whole wall out. If you don't, there will be a big caulk joint where the SS meets the DW along the entire vertical edge.
Like Mike stated, the pan wasn't set correctly, and these are the consequences.
William
My current DIY project..
Vegas Sparky is offline   Reply With Quote
The Following User Says Thank You to Vegas Sparky For This Useful Post:
oh'mike (01-20-2015)
Old 01-20-2015, 06:03 PM   #13
Rewards Points: 12
You folks have been tremendously helpful. I am very thankful to you.
The Following 2 Users Say Thank You to Pleashelpme For This Useful Post:
oh'mike (01-20-2015), Vegas Sparky (01-20-2015)
Old 01-20-2015, 08:05 PM   #14
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I think what the problem is is that the shower pan has a lip extending up and it is holding the swanstone material out. Since it causes the piece to angle outward starting at the top of the lip it gets worse the further down you get.
I don't know how to fix it myself \. Not my trade.
a suggestion though: the plywood needs to have a relief cut into it so the pan lip end up flush with the plywood.
but since that isn't likely to happen: furring strips the same thickness of the pan lip to shim the SS out.
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 06:42 PM
Kitchen and Living Room Installation bejscott Insulation 1 08-10-2012 12:18 PM
Laminate floor installation tomkk Flooring 6 02-17-2012 04:20 PM
Exterior Flue Enclosure Repair edge10 General DIY Discussions 6 08-03-2009 08:15 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
