Pass Kitchen Vent Through Joists? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-11-2015, 10:49 PM   #1
Rewards Points: 86
Pass kitchen vent through joists?
As part of an upcoming kitchen remodel, I'd like to move the electric cooktop to the other side of the room, away from the existing 6" round vent exit.
Naturally, the joists run the wrong way to make this easy
Above the kitchen is a bedroom.
Is it possible to drill through 4 or 5 of the 9" joists to pass the new vent hose to hook into the old? I assume there are regulations about how much material can be removed. Is it possible to go to a smaller or rectangular pipe, sister the joists, some other idea?
joylove is offline   Reply With Quote
Old 07-11-2015, 10:56 PM   #2
Rewards Points: 17,896
Not going to happen.
Post some pictures.
Install a recirulating vent and no cutting or drilling needed.
Old 07-11-2015, 11:29 PM   #3
Rewards Points: 86
Pictures speak 1000 words.
here's the existing.
The house has no gas. I have an induction cooktop and slide-in oven. In the cooktop instructions it says the cooktop cannot be installed above an oven due to heat.
The modifications planned are to
Lower the non-load-bearing wall at the fridge to just above the splashback.
Move the sink to the end
Move the fridge out into the eating area
**move the cooktop to the area where the fridge is now**.
The joists run parallel with the existing countertop.
Here's the proposed layout. I've used window and a 1/2 wall to indicate the area that is newly open to the living room.
The sink will be on the end.
The oven is a 30, the cooktop is a 30, the DW is a 24, fridge is a 28.
The cooktop I would like at the left of the dishwasher. There are two reasons; one is to mean I don't cook with my back to the living room, and second that the flow isn't quite right with the cooktop immediately beside but not above the oven.
I wold leave the microwave where it is and add a vent above the cooktop
Kitchen Sink Drain Vent Tfraser Plumbing 21 06-30-2015 04:55 AM
Running kitchen vent through top plates Malcolm Building & Construction 24 06-04-2014 09:38 PM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Two kitchen sinks on one vent? Alsomee Plumbing 1 09-30-2007 07:36 PM
