Paint First Or Install Tile Floor? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 07:25 PM
Paint first or install tile floor?
I'm a novice when it comes to Home remodeling, but I'm learning. Just took down wall paper and have paint and tile ready to go. Which should i do first? and why?
dpatters2063 is offline
Old 06-08-2009, 07:37 PM
Usually the paint 1st
So you don't get paint on the tile
Scuba_Dave is offline
Old 06-08-2009, 07:42 PM
the Musigician
DangerMouse's Avatar
what he said...
my floors will be the LAST project i take on here. too easy to mess them up otherwise.
DM
DangerMouse is offline
Old 06-09-2009, 10:57 AM
RDS
Rewards Points: 150
Yeah, paint first. I wish I had. I hired a guy to install tile in my bath, and he requested that I *not* paint first, saying his wet saw might cause some splatter on the walls -- but in fact that didn't happen, and then when it came to paint I had to cut in carefully to the tile. I won't do it that way again.
RDS is offline
Old 06-09-2009, 11:20 AM
Rewards Points: 358
I would paint first... Maybe you will need to do a little touch up after the tile work. Or, worst case... If the touch up work shows just repaint. The second time with the same color is way easier than the first and should only take one coat.
Rege
RegeSullivan is online now
Old 06-15-2009, 07:27 PM
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
Paint 1st! Run the paint as low as possible without touching the slab/ subfloors. Then even if you have a wet tile saw you can drape the wall if need be.
It only makes good sense as the tile should really be treated as a finish material and if it gets so out of hand that you get grout and adhesive on the walls then you or your tiler should consider working out of another room.
Take care and be safe.
James
Paragon is offline
Old 06-15-2009, 08:23 PM
the Musigician
or another career..... heh heh
DM
Old 06-22-2009, 02:16 AM
Rewards Points: 1,016
Prime and paint first - then be prepared to take care of whatever may happen during the tiling and final plumbing (splatters, hand prints, oops's, etc.) by another coat and/or touchup.
vsheetz is offline
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
what sub floor for slate tile? gk02 Flooring 10 02-26-2009 09:49 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 06:32 PM
a couple of ceramic tile install Q's DanBress Flooring 5 06-22-2008 10:01 PM
